Drag Racing Tech
Tubes and screws
Old Aug 4, 2017 | 09:48 AM
pressureprows6's Avatar
Default Tubes and screws
Tubes and screws needed for Hoosier 27.5/11.50 on a 15x10 wheel?...530hp m6 car taken to track once in awhile.
Old Aug 4, 2017 | 11:27 AM
01ssreda4's Avatar
Does Hoosier recommend them? Is the tire spinning on the rim when launching?
Old Aug 4, 2017 | 02:32 PM
nj02z's Avatar
Glue the bead.
Old Aug 4, 2017 | 02:47 PM
Glue?....tell more please.....I did online chat with hoosier awhile ago and they said it was up to me whether I wanted to run tubes or screws....Im not really wanting to do either if I dont absolutely have to...I'm new at this too and dont wanna do something stupid....
Old Aug 4, 2017 | 03:30 PM
nj02z's Avatar
Search Tire bead sealer.
Old Aug 4, 2017 | 04:51 PM
Old Aug 4, 2017 | 05:17 PM
nj02z's Avatar
Napa has bead sealer. Napaonline.com
Old Aug 5, 2017 | 12:24 PM
Nathaninwa's Avatar
I just went through this only slicks and decided after they were powder coated to use a 3 inch 36grit roloc on my air 90* and touch the bottom of the head surface up, then have my local tire shop mount them up with bead glue/sealant. Went through a full set of tires with zero leak down and several 1.3x launches with zero tire slip
Hoosier 28x10.50 stuff sidewall running 15 ish psi
Old Sep 21, 2017 | 02:12 PM
yoshgixxer's Avatar
High tack is great ****. I ran that on a set of 15x12's never had the tire turn on the rim with 29.5/10.5 pro bracket radials. 1.18 60' 4.88 1/8 mile. Car is 2600lbs with a 598" BBC on spray around 16-1700hp
