Drag Racing Tech
fuel cells
Old Aug 25, 2017 | 01:33 PM
motivman50's Avatar
Default fuel cells
I have a 94 Camaro drag car and it has a poly fuel cell but I want to go to efi. can I still use the fuel cell.
Old Aug 28, 2017 | 11:43 PM
Nathaninwa's Avatar
Does it have an extra fitting on top for a return line?
Old Aug 29, 2017 | 12:20 PM
jimmyp3353's Avatar
A little more info would be helpful. Where is the cell? Are you currently running a return? What size line are you using? In short though, yes, you just need to have a pump and regulator for EFI. Are you already using a return? Even if not, you can drill a hole and put an AN bulkhead fitting on there.
Old Sep 2, 2017 | 02:28 PM
motivman50's Avatar
Thumbs up fuel cell
thank for the info, I'm at the point now were I needed to figure out carb or efi. have not ran any lines yet. but my cell has 2 fittings on top and 2 on bottom. it is a poly fuel cell
