Drag Racing Tech
AC??? Help.
Old Jul 3, 2004 | 10:04 AM
Noyzee's Avatar
8 second mod
Question AC??? Help.
wasnt sure where to post this, and i figured this would be the section for weight reduction.
I know its been talked about befor, but i pulled the ac out of my car. the part that goes into the heater core looks like ****, any way to remove the parts that are sticking out?
Thanks alot.
Old Jul 3, 2004 | 01:54 PM
SilverGhost's Avatar
Motorboater
what are you talking about, the metal/rubber lines that run from the core to the dryer canister? those should just ubolt off the core if i'm recalling right.
Old Jul 3, 2004 | 03:52 PM
DietCoke's Avatar
Thanks alot.
That part (EVAP CORE) is removable, but it's a major pain in the *** to do so. Takes several hours and you have to remove the dash from the interior to get to it.
Old Jul 3, 2004 | 07:55 PM
GM Muscle's Avatar
I covered mine with black rubber boots for now and it doesn't look so bad. Even if you remove the EVAP core it still won't look right.
Old Jul 4, 2004 | 01:11 PM
Noyzee's Avatar
8 second mod
I found out this weekend the only way is to remove the dash. I'll rip it out when i do my 10pt cage, the dash is coming off then anyway. For now i will have to cover it up.
Thanks
