seems the ms3 out performs the ms4
The question at that point is will the rise in peak power make up for the loss in low end power over the distance you plan on racing.
A big problem that people run into is they don't match the cam to the engine/transmission/gearing and weight of a vehicle. Besides changing cams you also need to look at the valvetrain/heads/compression/converter/gearing among other things.
In simple terms bigger isn't always better with all other things being equal.
The difference is more than just the @.050 that you see and more lift, but if your heads will flow above .600 well the ms4 is a good idea. They do use the same exhaust lobe also.
For most street/strip and mid range builds the ms3 is more than enough and often too much. If you drive an M6, do you really wanna look like a cowboy ridin a bull in the mall parking lot trying to park at Dillards? It is a fun cam that makes power no doubt, but keep in mind you wont be above 3k all the time.
