What exhaust setup are you running?
https://ls1tech.com/forums/dynamomet...t-upgrade.html
You have more cubes and everything you will benefit greatly from throwing the Y-pipe away.
If you remember my car the exhaust has went through several changes. Going TD made it feel like a different car. Although I didn't have a cut out like you. Then going from 1 3/4" to 2" headers made many changes in the engine. All for good. Maybe the only negative is I have to get the pass. rear plug from the top now. The big pipes blocked access from under the car. No big deal
You do have a bigger motor with the 1 7/8" already. Maybe start with the TD. How much do you want to spend also. Good luck man.
Since you posted in the drag section, I assume you are looking for flow and light weight. 3" to 4" merge and a 4" bullet. Seems to work for me.
2'' primaries if you can and duals for sure.
