Drag Racing Tech
ls1 potential
Old May 1, 2018 | 01:15 PM
Mike Morris's Avatar
Mid 10s here with the front sway bar on and stock snowflakes. I would have your tubes welded on the 10 bolt and add a girdle. Then ditch that LS6 and go big on the intake side. I would stay away from Vikings if you do a lot of street driving.
Old May 1, 2018 | 01:29 PM
Tuskyz28's Avatar
Zmgcamaro went 10s all motor with a eps cam, 32XX weight and serious suspension.
Old May 1, 2018 | 02:26 PM
ragtopz28's Avatar
Originally Posted by Coach 02 A3 Z/28
This is what I would do!!!!!
Afco's doing work!
1.34 60' and barely lifts tires (just as Madman ordered)
Old May 1, 2018 | 02:29 PM
lsxgirl's Avatar
Originally Posted by 98CayenneT/A
Where are you shifting at?
If it were me I would go to a yank pt4000 or even better a pt4400. That 3200 is way to small for that cam if you're chasing e.t numbers. I would also go with a msd intake. They just keep pulling.
Also put a real set of tires on the back. Imo stock suspension can carry you a long way in a auto. I would leave it for now.
Post a time slip
Driving on the street would be ok with a 4000 stall?
Ill try to find my time slip, recently made a move and will have to look for it.
Old May 1, 2018 | 02:31 PM
lsxgirl's Avatar
Originally Posted by ragtopz28
Afco's doing work!
https://www.youtube.com/watch?v=CV7nnRefB4s
Is that car an ls1?
Its REALLY putting in the work!
Old May 1, 2018 | 02:34 PM
lsxgirl's Avatar
I'll definitely be looking into afco's, thanks so far for all the responses. I also have a fiberglass hood so I know I shaved some weight there as well. Do most people recommend msd intake over the FAST?
Old May 1, 2018 | 03:43 PM
98CamZ28's Avatar
What is your 60ft like now and what was your MPH? That'll tell a lot of the story. I'd recommend getting some real meat under the car too, some nice 275/60/15 drag radials on some 15x10 w/7.5" back space or 15x8 w/5.5" BS.
Old May 1, 2018 | 03:47 PM
Depends on the cam and where the car makes power. If you are past 6600 a ported MSD would be best.
Old May 1, 2018 | 04:40 PM
ragtopz28's Avatar
Is that car an ls1?
SBE iron 6.0 and a 150 shot.
Old May 1, 2018 | 05:01 PM
98CayenneT/A's Avatar
Yes, especially with already having 3.73's
Old May 1, 2018 | 07:19 PM
lsxgirl's Avatar
Rev limiter is set at 6500
I'm making my power at 6000 (that is according to the tuner)
Old May 1, 2018 | 08:18 PM
  #32
Doug G's Avatar
Full slip would show a lot....like where you need the help.
if you're 2.xx 60', there's a lot to be gained there also .... but that could end the 10 bolts life pretty quick too.
Old May 1, 2018 | 08:44 PM
  #33
Ported Fast 102 with a 102 NW TB will work nice.
Old May 1, 2018 | 08:58 PM
  #34
Not behind a auto
Old May 1, 2018 | 09:12 PM
  #35
sxc Z28's Avatar
4000 stall should be number one priority. Suspension, adding power, and attacking weight are next.
Old May 1, 2018 | 10:05 PM
  #36
Darth_V8r's Avatar
Moderator
I did msd and fast102 back to back on my old motor. They crossed at 6400. Above 6400, msd takes off, below 6400, it's fast all the way.
I think you should consider revving higher. On your upshift you want to land on peak torque which is 4800-5000 rpm
Old May 4, 2018 | 08:11 PM
  #37
N2RACINGLS1's's Avatar
The correct parts will go a long way. My car is an LS1 346 CI and 10.47 best NA with a 1.38 60 foot time at 3,370 lbs. I personally think you are shifting to low. I shifted higher then that with the stock untouched 91K LS1 with LS1 intake.
I will also say 11.6 ET first time out is something you should be proud of.
N2
