Battery relocation questions
1) Is the summit aluminum box the only sealed box that will fit in the spare tire area?
2)What size wire should I use? I see summit sells a kit with 16ft of 1 gauge for $40. is that big enough? Can I get welder's cable cheaper?
3)What's the best spot to mount the disconnect switch? I think I prefer a regular switch over one with a lever. I considered mounting it where the rear hatch key hole was.
4) Will the stock battery work or should I get a red top(or something else)
Any other tips or suggestions? Thanks a ton.
2)1 guage is fine. it is what I have. that price seems right.
3)I have my switch throug the bottom center of my liscence plate. You will need to have yoru rear bumper support removed to use the switch without the T handle since the switch will need to mount in the bumper if you put in in the plate as i did. i would not put in in the keyhole, that would look rather odd. i have a smoked plate cover over my switch when not at the track and you can hardly notice the thing.
4)You cannot use the stock battery. you must use a dry cell such as the optima red top as you mention. I myself use the optima red top as well.
I definitely prefer a red top over a liquid battery inside the car. As far as the switch goes, to each their own. I mounted mine in a spot that wouldn't be bothered by the t-tops or anything else. Here's the pics of how I ran everything.
http://www.derty.org/photogallery/ca....php?cat_id=47
Thanks,
Brad
Ross
Brad
