I want to wheelie, famous 1 wheel lift
So Im wondering what to do to get the fbody famous one wheel wheelies?
And when you start changing the suspension, what makes it better or worse?
Whats better for wheelies, stock torque arm, am or tunnel mounted?
LS1Tech Premium Sponsor
Oh boy, a lot to cover here
First, a long arm works better for stick shift or car making less than 600whp . It brings your instant center farther forward and puts more lift to the front end.
As for the one tire only wheelie, that is usually what people try to avoid. This is caused by suspension flex from the lack of sway bar/anti-roll bar on the rear. If you want it to do this for some reason, the simply remove your rear sway bar. But this is usually not consistent or good for the chassis
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Thats good to know. But you mentioned its not good for the chassis?
Yea I want to pull some wheelies, 1 wheel because Im sure its alot easier to get there but Im definitely gona put more power into her soon after that and Ill be upgrading a bunch of suspension parts and come here asking on how to do it the right way
BMR- all 600 RWHP are not the same/equal. A naturally aspirated car go hit the tires differently compared to a forced induction car.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
First off, wheelies are cool for pictures (if you going up, you're not going out!).
I was having serious twist, as in, driver tire 12-18" compared to only a couple of inches passenger side.
A call to a certain "Madman" for some shock settings and a ARB recommendation solved it (I have a short TA). "He" told me, you want the tires an inch or so off the ground ONLY, for max weight transfer and "moving out". With his setting, my 60' went from 1.46 to 1.34.
