Harlan 2-step installed today!
Even with a 1.82 1st gear, the car feels reallllly nasty coming off the 2-step (set at 4K rpm) and brake at full throttle. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I'll try it out at the track tomorrow night.
AFAIK, the only problems with 98's and the Harlan 2-step is with M6 cars, and that's only if you're using the clutch pedal itself as the activation switch.
<strong>I'll probably make a couple of easy passes to make double sure things still look OK, but I do plan on some full 1/4 mile passes...
AFAIK, the only problems with 98's and the Harlan 2-step is with M6 cars, and that's only if you're using the clutch pedal itself as the activation switch.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.
<strong>how is it any differnt than normal launching other than you have a throttle stop? how is it making more power?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Because it still lets the converter flash (to wherever it flashes to) when you release the transbrake/2-step. It's almost like a manual car in the sense that when the brake releases, WHAM, you're moving.
Kevin, I would let you drive, but I need somebody to run the videocamera. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very easy install. The unit plugs into the factory coilpack wiring harnesses, and there is a ground wire, and an activation wire. That's it.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very easy install. The unit plugs into the factory coilpack wiring harnesses, and there is a ground wire, and an activation wire. That's it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You shouldnt have told me that. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
