Drag Racing Tech
Launching a 6-Speed LS1
Old Sep 24, 2002 | 01:08 PM
cablebandit's Avatar
Default Re: Launching a 6-Speed LS1
stock rear and suspension....dump the clutch at 4000-5500 rpms.....
Old Sep 24, 2002 | 01:26 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Aaron said he had a 12 bolt. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I would not dump a 10 bolt more than 3,500 to 4,000 rpms. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Coach
<small>[ September 24, 2002, 01:27 PM: Message edited by: Coach 02 M6 Z/28 ]</small>
Old Sep 24, 2002 | 01:36 PM
mykdiver's Avatar
Get a Denney's Drive Shaft, then dunp at 5000 RPM and hang on! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 24, 2002 | 01:47 PM
CHRISPY's Avatar
This technique will get you good 60's and also save your drivetrain.
at the line rev the car to your desired launching rpm. (say 5000rpm)
When the third yellow lights up lift your foot straight up off the clutch as fast as you can while flooring the gas at the same time. (One fluid motion) This will load the drivetrain and greatly reduce the shock on parts. you will still cut great sixties with this technique. It takes a little while to get used to but works awesome.
Cheers,
Chris
Old Sep 24, 2002 | 10:14 PM
Just what Chris ARE 360 siad. This is what I have always done. It works! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Good luck to ya. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Coach
Old Sep 24, 2002 | 10:30 PM
DERTY's Avatar
The Bull
Aaron, I've broken a few parts just as well. Just a fact of racing. However, once you get where you are now it should be a lot more fun. I basically start with my tires a little hard and then work my way up the RPM's. When it begins to bite good then we work on the tire pressure. I'd rather blow the tires off the car than to bog the motor and driveline down. Less stressful.
Once you get a comfortable launch RPM, mine is currently 5000 to 5500 on 26" x 11.5" Hoosiers then you can work on dialing in the tire pressure a little better. It's just a lot of experimenting with launch RPM and pressure at this point! But if all this is too scientific, just bang her off the revlimiter and hold on! That works too, lol!
Old Sep 24, 2002 | 10:57 PM
JS12's Avatar
i was launching my 10 bolt with BFG's at about 5k-5.5k and cut a 1.70 and a bunch of 1.8's. now i have a 12 bolt and launch at the limiter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> broken driveshaft? oh well get a new one <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 25, 2002 | 12:27 AM
gator's 99TA's Avatar
i launch way up high at around 6800 or so to a bogging 1.64 with my tire combo.
Old Sep 25, 2002 | 12:33 AM
98_WS6_M6's Avatar
Default Launching a 6-Speed LS1
I have a 98 TA with complete BMR suspension and Hal Struts and Shock, exhaust (complete), 4.11 gear, Moser 12 bolt rear end, hypertech PP3, and E.T. Streets. How should I launch this thing? I keep breaking parts. Rear end, 2 BMR Torque arms (now have extreme duty torque arm) pinion angle is set at negative 2, and I've broken one driveshaft. How should I come out of the hole?
Old Sep 25, 2002 | 12:45 AM
Wow, Sorry for the bad luck. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I have 196 6,500 rpm launches on my M6 Hot Rod and have not broke anything in the drive train. I had everything BMR has for our cars with no braking with 4.56 gear for 1/2 the season and now I have 5.13 gears with 30x9x15 slicks. I now have a Madman tq arm and solid motor mounts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Start out with 4,500 rpms and work your way up. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 25, 2002 | 03:31 PM
98_WS6_M6's Avatar
What pinion angles are you guys running at with manuals? Right now it's set at negative 2.
I will see how it works this weekend at Morocco with the new BMR Xtreme duty torque arm it's much more solid than the other BMR trak pak torque arm.
