26 vs 28's
28s definitely have their place where extra traction is needed. Most people make the mistake of not gearing the car properly for the taller tires. I'm running 29s not but due to my trap speed and gearing, they work great for me. I'll may be going to a 30" tire when I get the 5.13s installed. That is only if and when I see that I need to lower the trap RPM a little.
Why the heck would you go to a 3.89 gear if you're undergeared (crossing too low) now? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Also you mentioned doing the 3 inch Y with dual cutouts and a quiet catback. I think that is a great idea.
I would do the Ypipe, catback and injector swap, 26 inch slicks at the same time, reflash and retune the car on the dyno.
Then you wont need to worry about injector
scaling and all that ****.
Run a stock descreened MAF and just set your AF to where you want it and your timing. Then look at setting shiftpoints etc.
Easy as pie. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck,
Chris
<small>[ September 30, 2002, 09:26 PM: Message edited by: Chris ARE 360 ]</small>
http://www.pbase.com/image/5269394
Interesting sequence of pics...
1)
http://www.pbase.com/image/5269910
2)
http://www.pbase.com/image/5269912
3)
http://www.pbase.com/image/5281172
<small>[ September 30, 2002, 12:12 PM: Message edited by: Pro Stock John ]</small>
I think I can hook a 26x10.5x15 slick heck I over hook now I can get the front end up a foot on a 1.59!
Alex, last run, we decided to look at the pcm shift points at a later date and not to flog the car anymore... We ran it 6 times and two of those runs were messed up due to the 1-2 bog.
There is no such thing as hooking too hard with an automatic. Sure, with an M6 you might cause a bog but the TQ converter takes care of that with the auto.
0.0 revolutions of spin is perfect.
