26 10.5 16 et street air pressure?
What do you guys usually run yours at? Last night I was at 18 psi I did a good burnout, and the slicks spun for about 10 ft leaving the line @ 2000 rpm.
Is the air too high or could it have been the track prep?
I've had to vary mine from 25 to 16 psi to hold depending on track prep, temperature and amount of fuel in my tank. It takes trail and error to determine.
Yes, colder temperatures less air. At least that's my experience at the track. Tires and track are warmer in hot weather and will hold better so you can run more air.
More air is less drag so you want the pressure as high as will hold traction.
I run 10-12 psi and pull the wheels cutting a 1.56-1.59 60ft with E.T. streets.First off ,do a short spin in the water then pull forward 4 feet and do a good smokey burn out.Your gonna need to launch at 4500 for starters cause your car is gonna hook so hard it will fall on it's face.Hope you have a good rear and clutch before you do this.I have run this tire psi for the past 5 years so dont let anyone tell you that the tire psi is too low.If you wanna hook thats what you have to do.
Originally Posted by 02SOMWS6
I run 10-12 psi and pull the wheels cutting a 1.56-1.59 60ft with E.T. streets. I have run this tire psi for the past 5 years so "dont let anyone tell you that the tire psi is too low".If you wanna hook thats what you have to do.
