Drag Racing Tech
Chassis Cert??
Old Dec 7, 2002 | 08:48 AM
y2khawk's Avatar
Default Chassis Cert??
OK, so I've been doing the research on getting a chassis cert for 9.99 to 7.50.
Seems there isn't a set spec for a full bodied car in that range, but most go by SFI 25.1C or 25.1D
Can someone confirm that??
The NHRA rule book isn't too specific on it. Should I just go ahead and order the chassis spec from SFI??
The conversion for my cage is on the way, and plan to start ripping the interior out after christmas. Got a week off work <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Just curious what I should add to the shopping list <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 7, 2002 | 09:24 AM
Joe Kizzire's Avatar
Resident Grump
Default Re: Chassis Cert??
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by y2khawk:
<strong>OK, so I've been doing the research on getting a chassis cert for 9.99 to 7.50.
Just curious what I should add to the shopping list <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Matt is your rollbar crommoly??? Mild steel won't work so converting what you already have is out. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Dec 7, 2002 | 09:30 AM
y2khawk's Avatar
Yes it is. Currently 8 point chromoly, TIG welded as required. The halo, pillar bars, and dash cross bar that are on the way are also chromo.
All 1 5/8"x.083 4130
Old Dec 7, 2002 | 11:16 AM
H82BBad's Avatar
you can get it certified at Milan.call some of the local tracks at the begining of the year they will have cert days.
Old Dec 7, 2002 | 11:31 AM
Resident Grump
Matt the dash bar is not required if you have a stock firewall.
Old Dec 7, 2002 | 01:48 PM
PHIL H's Avatar
Your chassis should certify no problem as long as you have your rerquired 6x6 plates on the floor and your tubing will certify. I belive with moly they give you a 10% deviation in wall thickness but mild steel is like 1%. You will be good to 7.50 or 180 mph as this year you have to have a 25-1C car to run over 180. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck
Phil
Old Dec 8, 2002 | 12:11 AM
y2khawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by H82BBad:
<strong>you can get it certified at Milan.call some of the local tracks at the begining of the year they will have cert days.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good to know. I'll probably go to Stanton instead though. Might as well go to a track that hooks if i'm gonna go to any track <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Joe
That's what i mean, is there anywhere other than getting the SFI spec that will tell me that kinda thing??
Other than some small holes for gauge senders, and the plate over the heater hole the firewall is untouched.
Old Dec 8, 2002 | 12:26 AM
Resident Grump
Matt it's all right there in the rulebook...
The specs are in the back as for cage constrution etc....
Give Madman a call... he'll be glad to help you...
Old Dec 8, 2002 | 12:29 AM
H82BBad's Avatar
In the early spring they have cert inspectors sometimes when the track isnt open. Check with them and they will give you dates when open.
Old Dec 8, 2002 | 12:36 AM
y2khawk's Avatar
I followed the cage stuff when i did the 8 point.
My biggest issue is about the rest of the stuff. Is the cert just on the cage or the full chassis as well?
Just wondering if I gotta do other stuff to the car. The main structure hasn't been altered, just welded to for the cage, subframes, etc.
