Drag Racing Tech
5 point harness question
Old Aug 18, 2004 | 12:31 PM
WicketMike's Avatar
Default 5 point harness question
with the 5 point harness, is it easy to install? is there anything else i would need to buy to make it fit and work?
thanks
Old Aug 18, 2004 | 01:17 PM
kp's Avatar
kp
A roll bar if you dont have one
I just used the stock seatbelt bolts and opened the holes a tiny bit on the harness ends, I used the wolfe bar for the crotch strap and used an individual wrap around shoulder harness on the crossbar of the roll bar.
If you dont have a roll I wouldnt do a 5 point harness but thats just me..
Old Aug 18, 2004 | 01:28 PM
WicketMike's Avatar
i just had the roll bar installed. so i should be ok, where does the crotch strap attach to? would i have to buy a crotch bar to put under the seat?
Old Aug 18, 2004 | 02:04 PM
kp's Avatar
kp
You can just drill a hole in the floor under the seat and use a couple big washers for the crotch strap, the wolfe bar bolts across the two front seat bolts. I had one here so I used it
Old Aug 18, 2004 | 02:48 PM
SilverGhost's Avatar
Motorboater
I just drilled and used a bolt and washers for my crotch strap, works fine
Old Sep 11, 2004 | 09:32 PM
WicketMike's Avatar
i got the 5 point harness last week and i have no idea how to put this thing in the car.
where does each strap lock onto and with what.
this might be the stupidest question ever
thanks
Old Sep 12, 2004 | 12:32 AM
SMOKIN01TA's Avatar
thanks
shoulder harnesses go on the rollbars cross bar, mine has a bracket to hold the harnesses from sliding side to side, for the lap belts use the stock seat belt bolts, and i used the croch strap bar for the buckle.
Old Sep 13, 2004 | 06:22 AM
chris98pace's Avatar
Here are a few pics for the padding and the rear straps. I got a bar from thunder racing for the crotch strap. It bolts on to the front two seat bolts.
Lap straps go on the same place that your stock lap belt goes. You need a special socket , i forget the name.
I had a couple mini brackets welded in for the rear straps so they did not slide out and in.
The summit padding I had was crap. If you get it, get it in black. My pagging faded in 2 weeks.
without mini brackets for the straps they just go over the bar.
Padding. Some of the padding peeled off too. The velcro stocky did not last very long. I bought a big two sided roll of velcro and used that instead of twisty ties. easy to take the stuff on and off as needed.
Old Sep 13, 2004 | 09:49 AM
WicketMike's Avatar
nice
thanks guys
Old Sep 13, 2004 | 07:38 PM
SMOKIN01TA's Avatar
called a torx socket, i believe its a t47 size
