Drag Racing Tech
Does removing the front sway bar really help?
Old Aug 23, 2004 | 05:20 PM
fast01's Avatar
Default Does removing the front sway bar really help?
I have yet to try it because I'm too lazy to crawl under the car after a 2 hour drive to the track and remove the sway bar only to put it back before I go home. I was just wondering if it makes enough of a difference to go through all of the trouble. I know some people might say just leave it off, but the car is my daily driver (200 mi week) and I prefer to drive with it on. Thanks!
Old Aug 23, 2004 | 05:27 PM
next's Avatar
If you're spinning, yes it's a big help.
Old Aug 23, 2004 | 06:47 PM
eswolfgang's Avatar
Why not just undo the endlinks, won't get the wt savings but it won't function.
Old Aug 24, 2004 | 10:04 AM
1fastWS6's Avatar
Yeah, I just remove the end links. Takes 5 min. to do. The car still handles just fine. Don't even notice it unless you are doing hard cornering.
Old Aug 24, 2004 | 02:03 PM
jeffws6's Avatar
I just took mine completely off.... I love it.... the front end lifts more,thus transfering the weight to where it should be...the rear
Old Aug 24, 2004 | 04:44 PM
BADSZ28's Avatar
I too would like to hear results of this.
Old Aug 24, 2004 | 08:12 PM
next's Avatar
This is the first mod I've always done to every muscle car I've owned. Yes, you will loose a little cornering, but I'm a 1320 racer.
Old Aug 24, 2004 | 10:05 PM
98TAauto's Avatar
ive never touched mine.. but ive had no need to remove it since ive always hooked fairly well. Stock shocks here still also and mid 1.5;s cam only.. 1.58's on nittos
ive yet to make any passes with the heads for a good 60 but i would hope for low 1.50's
Old Aug 25, 2004 | 02:00 AM
fast01's Avatar
Thanks guys! I guess it can't hurt to give it a try. I'm going to Englishtown on Saturday, I'll keep you posted.
Old Aug 25, 2004 | 05:05 PM
mike c.'s Avatar
take alook at my post just lost 52lbs in this section.
