Drag Racing Tech
approximate # of passes on BFG or nitto
Old Jan 13, 2003 | 06:01 PM
Classic's Avatar
Default approximate # of passes on BFG or nitto
I was just wondering approximately how many passes you get on BFG radials and how many on Nittos. Now I know it all depends how long you burn out and stuff but I was just looking for a ballpark figure. Also, I've been doing some searching and it seems as though the BFG are the best DRs if you aren't going to use them on the street (which I will be doing - dedicated drag wheels). Which would you suggest for the 16'' wheel?
Thanks
Old Jan 13, 2003 | 06:10 PM
jleews6's Avatar
Default Re: approximate # of passes on BFG or nitto
I cant tell you how many runs i got out of my nittos but i just took them of the car and i got about 22000 miles out of them with many runs at the track and even more on the street.I had 315 35 17 and i liked them.
Old Jan 13, 2003 | 06:19 PM
LOnSLO's Avatar
Love the Nittos for street/strip duty, but if you're going to change wheels at the track, then go with the BFGs. They have a slightly softer compound, and a semi slick area in the middle of the contact patch.
Old Jan 13, 2003 | 06:36 PM
Classic's Avatar
Lo - the idea would be to put the tires on 5 minutes before heading to the track, then racing, then coming home and taking them off. I won't be changing them at the track but close enough.
I'm trying to get these set up before our track excursion to SDR in a few weekends - give Allen a little surprise..haha.
Old Jan 13, 2003 | 06:40 PM
NastySSoo's Avatar
I use Nittos for every day and track also. But if their just for the track, and you live close to it, why not use ET streets??
Old Jan 13, 2003 | 06:51 PM
Classic's Avatar
Nasty - I would love to use ET streets, but I don't plan on blowing my 10 bolt up on the first pass...haha.
Old Jan 13, 2003 | 07:02 PM
Classic's Avatar
Let me refine my question one more time now that I'm thinking about it again - how many more passes would you get out of nittos vs. BFGs considering only track use and say an hour drive to the track. Basically would you get twice as many runs out of nittos as BFGs?
Old Jan 14, 2003 | 07:30 AM
LSWon2002's Avatar
I have 63 timeslips and unknown how many Ive lost or not gotten since Ive had BFG's and I DO get them warm (burn um pretty good) at first I did drive these tires every day but they do wear fast so now theyre on dedicated wheels - If you want a better hooking tire no doubt the BFG's win hands down, if you want OK hooking and longer live the nittos win...
Old Jan 14, 2003 | 07:57 AM
Bob Cosby's Avatar
I almost never drove my BFG's on the street. At the track, I did burnouts just like a slick. I liked to start with the BFG's arlready worn down quite a bit, and from that point, could get probably 40-50 passes out of them.
Old Jan 14, 2003 | 05:33 PM
offaxis's Avatar
I was using Nittos before I got like 60 + passes on them wiht john force looking burnouts.I just picked up some BFG`s and I dont think they hook as well as the nittos.I havent been to the track with the bfg`s but on the street i like the 1.61-1.65 60fts from the 245/50/16 nittos better. Dont think ill see that from the bfg`s.So i wont recomend them . Hope that helps
Jeremy
Old Jan 16, 2003 | 02:02 PM
timelord's Avatar
About 700-750 runs from BFG DRS,M6 1500-1800 rpm soft launch.
Since car got into 12.s can probably cut that # in half,need more burnout.
P.S.// We have very well prepared track,that helps.
Old Jan 17, 2003 | 05:50 PM
Wicked ls 1's Avatar
All depends on length of your burnout I race at rt66 and track prep is awesome i have over 250 passes on these tires and have probly 1/3 of the tread left car runs 12.6 with a 1.82 60foot on a a4. Hope this helps out <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 17, 2003 | 05:54 PM
Classic's Avatar
Thanks for all the replies. I decided to go with the BFGs especially when I found like the only ones left in the country apparently. We'll see how well they work next weekend.
Old Jan 17, 2003 | 07:14 PM
kazman's Avatar
200 -300 passes. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
