HOW BIG CAN I GO ON TIRES?!?!
i have the stock 17X9 WS6 wheels and i wanna get more meat on the back the 275's arent keeping me glued to the ground. i have the BFG G-FORCE KDW's, is this good or bad? i was thinking about getting something in 295's what should i get and how big can i go as well as what would you recommend the biggest i should go? i heard that 315's work?!
Humanitarian
315's are going to help you in turns more than they will help you with straight line traction.
Go with a 16 inch BFG Drag Radial and you'll grip better in a straight line than the factory 17/275 tires, they cost less and weigh less not to mention you need to mount them on a smaller 16 inch rim (less weight).
thanks for the replys, i didnt think that the 315's would work. what can i do for street tires? i just want to keep the same rim and want something a little wider on the back? what sizes would you recommend doing if any? but now i know what tires and rim to get for hook up <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> thanks a lot!
