Drag Racing Tech
how to fit 28" slick?
Old Mar 21, 2003 | 01:17 AM
BlackhawkSS's Avatar
Default how to fit 28" slick?
i have 15x10 weld draglites with 26" ET Streets which are needing to be swapped out.
What modifications are required to fit a 28x10x15" slick in there?
TIA
Jerry
Old Mar 21, 2003 | 01:38 AM
BigKevC5's Avatar
Default Re: how to fit 28" slick?
I run the 15x10 draglites also. With 28x10.5Wx15 E/T drags....they took quite a big of "massaging" to get right.
I had to cut part of the quater panel and "gently" <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> persuade the wheel well with a 15# sledge hammer.
But my first 1.36 short time made it all worth it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 21, 2003 | 05:00 AM
the massaging i dont have a prob with its the cutting of the quarter panel i dont like. i dont want to have to repaint my quarter panels <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Mar 21, 2003 | 06:55 AM
Camaroholic's Avatar
I had to:
-ding the little lip of metal in front of the tire so that it pointed forward instead of towards the tire
-trim the lip of the rear skirt slightly (but it is NOT obvious that I did anything)
-hammer on the inner fender well on the front inside of the tire - this required some fairly strong hammering to get at least a finger's width there, but eventually it got there. A little POR-15 paint and all's good.
-Adjustable lower control arms & panhard rod to center up the rear
I did not cut any metal at all. My wheels are Bogarts.
-Andrew
Old Mar 21, 2003 | 07:50 AM
so you didnt have to cut the quarter panel? ive already beaten the inner wheel well to fit my 18" wheels and tires (inside was rubbing) so i can beat some more no prob <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
ive got an adjustable panhard rod, but not adjustable LCA's, just BMR's.
i may go ahead and tryt his anyway.
thanks for the responses and keep 'em coming <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jerry
Old Mar 21, 2003 | 08:25 AM
Notice that he is running a 10.5W. That's an inch wider than a regular 10.5 tire. I'm running the regular 10.5" tire. (I'm actually running the 28 x 10.5 x 15" ET Drag Stiff Sidewall tire, to be technical <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ).
No complaints here. I had regular BMR non-adjustable LCA's, and the rear sat a little too far back (I've got a Moser 12-bolt also). I pulled it forward about 1/8" with some BMR adjustable LCA's. That minimized what I had to do at the rear skirt. I figure ~$230 for adjustable LCA's is cheaper and quicker than $500 for a bodyman and paint to rework the urethane rear skirt. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew
Old Mar 21, 2003 | 10:26 AM
JurisAg02's Avatar
you don't need those tires to hook up all 300rwhp ya got...puss LOL <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Old Mar 21, 2003 | 10:52 AM
i know you didnt <img border="0" alt="[punch]" title="" src="graemlins/gr_punch.gif" />
atleast my car isnt falling apart and sound like a train rolling down the road <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
