Drag Racing Tech
Launch pic from yesterday
Old Sep 19, 2004 | 07:56 PM
CHRISPY's Avatar
Default Launch pic from yesterday
The guy said this was when the car was on the way down
Any suggestions? I am squatting pretty hard to the right on the back. Need to put back in my RR airbag.
Slicks were at 12.5psi cold. Sixty was 1.54 for this run I think.
Old Sep 19, 2004 | 08:14 PM
gator's 99TA's Avatar
chris is your rearend narrowed? the centerlines look really nice and flush. good looking launch, looks like you are correct. a RR airbag would even out and hit the tires more equally.
Old Sep 19, 2004 | 08:26 PM
boseman350's Avatar
what psi are you guys running yor rear airbag ??
and also what kinda drag tires are those ?
Old Sep 19, 2004 | 08:27 PM
CHRISPY's Avatar
Thanks Gator.
Nope rear is still stock width. Those 15x7.5 Convo pros and 28x9 inch slick (27.3 OD) work really well.
I still have stock shocks, springs, PHR LOL!
BMR extreme TA with subs, hotchkiss LCA's
I am deciding between an airbag in the back or a solid swaybar over the winter
Old Sep 19, 2004 | 08:28 PM
boseman350's Avatar
im debating on et streets or hoosiers
Old Sep 19, 2004 | 09:18 PM
SilverGhost's Avatar
Motorboater
airbags are a half assed way of doing things IMO.
you should get the car squatting evenly using good rear shocks, drag bar, etc. i have my optima battery in the drivers rear which helps alot as well for weight distribution rather than having it in the passenger side which only compounds that problem.
Old Sep 19, 2004 | 10:22 PM
Nine Ball's Avatar
LS1Tech Co-Founder
airbags aren't half ***. They work and they are cheap. You can't pre-load a rearend with just shocks, that airbag can pre-load the rear.
Chris, you only need one airbag, the passenger side. The driver's side is never required. If you don't have subframe connectors, get some. Helps reduce the twist alot.
Old Sep 19, 2004 | 10:38 PM
JS's Avatar
JS
I agree the air bag is a cheapy fix,try one frosty..
I want the 1in sway like Wilwaxu has,he said it make a big difference and I dont want the added noised of a anti-sway.
I hope to be like u next spring except DR and 17's
Old Sep 19, 2004 | 10:50 PM
So Slow's Avatar
Nice Chris..
Old Sep 19, 2004 | 10:57 PM
Motorboater
no, you can't pre load with shocks, not what i was implying. but you can pre load with the drag bar, which is what i do and is a far better way to work with the car.
just my opinion that's all
Old Sep 19, 2004 | 11:03 PM
NA$TY-TA's Avatar
Chris what rearend? What tranny? Launch RPM?
Kyle
Old Sep 20, 2004 | 08:40 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Yes, but I can set my preload with an airbag in about 2 seconds, and also undo it in 2 seconds right after racing. And then you wont have that awful bind or racket that a drag bar makes on a street-driven car.
If you air up the air bag, you can lift that side of the car up about 1.5 inches and really stiffen the car up on that side. Plus, you can install an airbag in 10 minutes with a floor jack
Old Sep 20, 2004 | 09:25 AM
CHRISPY's Avatar
I have a RR airbag but need to put it back in the car. (Going to this week)
That is why I like the airbag, it doesn't affect normal driving.
Moser 12 bolt rear with 30 spline and 4.11's
Stock T56 tranny
Spec stage 4i clutch (iron disc)
launch is 5000-5500rpm
Old Sep 20, 2004 | 10:21 AM
CHRISPY's Avatar
BTW what pressure do you normally run in the airbag? I had 15psi last year and that worked ok.
I am going to throw it back in the RR spring this week
Old Sep 20, 2004 | 11:30 AM
1fastWS6's Avatar
I'm interested in the air pressure too. Just got an air bag and haven't installed it yet. Does anyone have any pics of it installed?
Old Sep 20, 2004 | 12:20 PM
CHRISPY's Avatar
I think the general rule of thumb is: The better the track is hooking, the more air you can run. I used to run between 12-15psi but have heard of guys with over 25psi...
Old Sep 20, 2004 | 12:53 PM
V6 Bird's Avatar
I would also like to comment that your air pressure needs to be measured when hot if at all possible. I ran my airbag @ 16-18 psi. It also really depends on what you said to be correct as far as the track hooking or not. I go as stiff as possible to hook, but then again, you dont want too much air or you will fight the car all the way down the track. The purpose of these airbags isnt for the initial launch but for keeping the car sqaure down track as well. Thats what these drag sway bars are all about. They were designed to keep the car straight down the track. Not much as to the launch, thats just an added beniefit of a drag bar
Mike
Old Sep 20, 2004 | 09:17 PM
02bluess's Avatar
FWIW... I usually run 15 psi in my rr bag, but decided to bump it up to 30psi (I was still getting a lot of squat at 15psi) this past Friday. Ended up getting my best 60' ever (1.42), but that was also my first time on the spray, so it's tough to say how much could be attributed to the extra psi... Track was hooking like a ****, too...
Old Sep 21, 2004 | 04:36 PM
BLK02WS6's Avatar
I've got a 1" Spohn swaybar (suspension techniques makes one as well) with the street type mounting - it straightened out my launches a whole bunch and is still quiet for street driving. Although I did put heavy washers on all sides of the lower end link poly's to keep them from pulling into the hole in the bar.
The pic in my sig is after the swaybar and the front bumper is perfectly parallel to the ground (1.55 to 1.57 60' times) - before my car looked similar to the pic above (didn't yank the tires quite as high).
Old Sep 21, 2004 | 04:45 PM
CHRISPY's Avatar
How heavy is that bar you have compared to stock? I was even thinking about a 1LE rear bar too. I believe that is 21mm compared to the stock 19mm. I dont want to add weight if I can help it. (already over 3600 pounds)
