M6 bogging revisited
nittos are better then street tires but still no match to hold this kind of traction
On a serious note, I think Im gonna quit launching like that before I tear the 10 bolt all the way the hell up. Its already swapping sides on me. It aint gonna work anyway so I will let'em spin a little. Im gonna put 4.10's in the 10 bolt before long even though I know its not gonna last just because when I eventually get to where Im making well over 400hp at the wheels Im gonna dump it on slicks at the rev limiter and break it. If it doesnt break on the 1st hit then I will hotlap it until it lets go. I get some sort of thrill out of destruction. I have always enjoyed seeing my property as well as others get torn up.
You really shouldn't launch like that on a 10 bolt. It's going to rip it to pieces, if that already hasn't started. Good luck.
lmmfao!!!!!
IS THAT ALL I HAD TO SAY
good job ram air
Has anyone seen or heard of this. I cant imagine an intermittant fuel pump only under accel. But I suppose it is possible there could be a wiring problem under unibody stress.
It's all is the first gear
With 3.42 gears in the rear, stock clutch and less than ~350 rwhp it's going to be tough to get less than a 1.8 '60. Until I went to the 4.10 gears in my 10 bolt I could not crack a 1.7 '60 to save my life. After the 4.10s it went down to 1.70-1.73 with the stock clutch.
