Time slip analysis/help please
I was hoping to not only beat my previous (stock) time but get into the low 13s or maybe even high 12s.
Well, I didn't even beat my stock time! I was hoping you all could give me some insight on how to launch with the M6 and what else I am doing wrong.
I am currently making 365 rwhp and 362 tq with the mods in my sig.
Stock I was at 308 rwhp and 314 Tq.
Stock:
r/t 1.064
60 2.273
330 5.994
1/8 9.036
mph 80.90
1000 11.638
1/4 13.832
mph 102.91
now:
r/t .458
60 2.339
330 6.063
1/8 9.128
mph 79.25
1000 11.718
1/4 13.938
mph 102.19
To launch, I brought it up to about 2000 and dumped the clutch and stepped on the gas - spun the tires and had to let off a bit to get traction. I didn't power shift because I was a little rusty and didn't want to break anything but the shifting was quick and precise.
I did a quick burn out to clean off the tires before the run. Rears are BFG KDWs - 285 40 17, and I did not lower the inflation.
So is this a matter of launcing at lower RPM, feather the clutch more, easing into the gas rather than flooring it? I would have thought that even with a bad launch, the extra power would have at least let me beat the old, stock time?
Looks like you are doing a lot of spinning. Even the 330' and 1/8 times are higher. Hook it up and you will see better numbers.
Dan
you are shifting so as to get the benefit of the higher
power/TQ? How peaky is that dyno result, and are you
staying on top of it (the power/TQ curve)? You may
have to modify your shifting habits as you modify the
powerband.
Steve, ONGRNGO - I was hoping not to get DRs simply because I only run a few times a year at the track - I mainly want to make the most use, and most fun with the power I have.
T6rocket - Yes, I thought the same thing. I just don't get why is wasn't faster?
MattG - I'll give those a try. I really thought it was grabbing pretty well but with the helmet, the noise from the other lane, my own inexperience and nervousness, etc. it's hard to tell. Where do you generally get to practice?
Jimmyblue - The torque curve is real flat - 325@2500,350@3100,362@5000. HP maxes @5700 but stays strong to 6200 and then drops off. I was shifting at 5500 to be a little on the conservative side and figuring that it would be at 5700 or so by the time I actually shifted.
So I should adjust my launch RPM a bit lower - balance between bogging and spinning, and shift about 500 to 1000 RPM higher.
How much difference will power shifting versus granny shifting make?
Assuming standard weight for a vert - where should my time be with the power I'm making?
Practice your launch on the street with the same tires you are going to run at the track.
I do agree with the shifting at 6500rpm!
Metalbeast: I know what you mean, that concerns me too but I had it re-tuned about two months ago after I replaced the Catco cats with Carsounds and added the LS6 intake and picked up about 10 HP and Tq across the band. It feels very strong.
One thing that bothers me - on my first run I launched the same, spun a bit, and missed third and hit fifth and ran 14.1. The second run, the launch was the same, but all shifting was quick and precise and I only picked up .2?
To learn how to launch I went out to a deserted side road and learned how to slip the clutch while keeping the RPM's up.
I rev to about 2500 or so and let the clutch out enough so it starts to grab and then floor the gas and slip the clutch so that I get very little or no wheel spin with the revs around 5000. Once I'm moving and I know the tires wont spin I let go the clutch fully. Sometimes I get a very slight bog but by this time I have good forward momentum and even though the revs drop a few hundred RPM the car seems to lurch forward so it doesn't slow my time.
I took me a couple times to get it sort of right but after about 10 times it should be second nature. Just dont do it too many times in a row without letting the clutch cool off.
Your shift point is another story, I shift my stock car at 6000. You powerband is certainly higher than stock with that cam and mods. You shouldn't be worried about revving it higher the bottom end can handle it. If in doubt about your top end and you didn't already you should upgrade your valve spings, pushrods and retainers which are the weak point of a stock LS1.
The time in my sig were for my stock Lid only SS on street tires.
