ARP studs for skinnies?
I am planning on ordering some ARP wheel studs and i was wondering if the Weld type lug nuts will fit the new studs? Or will i have to buy open end lug nuts? Also just wanted to know if ARP studs are really needed? The car is a daily driver so i am really just doing it for safety. Any advice would be appreciated. BTW they are 15x4 Draglites
Danny boy do you plan on grinding the caliper all the way down to fit the 15X4's without a spacer?? If so you got alot of grinding to do..... Tha bad side is th eopen end lug nuts are $13.99 for 4..... and you need 20. $55.96 for lug nuts and $27.98 for the extended ARP wheels studs for the fronts.....
Yes i am going to run a spacer. I was just asking about the shank style lug nuts i want to know if they will fit with the ARP studs? I know alot of guys run skinnies on the street, what do yall run? ARP studs? Stock studs? Open lug nuts? Regular Weld lug nuts? Thanks
I grinded the heck out of the calipers and it was not fun but I still have the stock studs and the weld lug nuts on pro-stars 15x3 on the front. It is a daily driver and no problems with it. I know two others that did the same thing and have had no problems.
Jody J.
