Engine dyno vs. your chassis dyno results for A2/A3/A4
Would like to take a quick "poll" of % driveline loss between engine dyno and chassis dyno results. If you never ran your motor on an engine dyno, then, no need to post up.
What I think would be interesting is % driveline loss instead of actual hp / tq numbers...list the % loss and the trans, converter, whether converter was locked, and which rear gear and tires.
A friend with a very similar combo saw a 22% driveline loss with a 4L60E, YTP4400 unlocked, 12-bolt with 4.11's, on 275/60/15 DR's (I use 325/50's for DR's which would have more loss due to extra weight). I have not had my motor dyno'd nor ran my current combo on the chassis dyno.
Just wanting the % drop vs. the raw numbers due to variation in correction factors, dyno types, dyno-to-dyno variation, etc. Not that other factors like engine temp, rear wheel / tire weights & pressures won't matter.
Plus, for those of you wanting to keep secrets,
, then the % drop won't give the real number.
Thanks for the info. Take care. Dave
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
I ran a gen 1 sb with a blower at just a touch over 1300 at 7000rpm. The car has a Bruno 3 speed auto with a 7000 stall and a nine inch rear end. The rear wheel hp was 976.
Kurt
Kurt
Kurt
Kurt
