Line Lock REALLY Needed?
Comments? I got Nittos on back, and I would think one would have to stay on the brakes to hold the burnout, which can't be good on the brakes, correct?
The line lock is nice to have for the burnout-but not absolutely necessary.
It's just what I was thinking. I rolled out of my burns fairly quick in May. I guess my 60's won't be that great this Friday, but I'll try to have fun until I can get the line lock installed.
Are the SLP ones ok?
The above comments are very good answers. To reiterate, a line lock is not a necessity, though it can aid in the prevention of wearing/damaging brake components.
It will help one control the car much better while heating up your tires. It also helps to clean off the tires when dirt/debris gets caught up in the tire.
There is also a "fun factor" involved. I'm sure others will attest to this; once you have it, you'll be using it in parking lots and on the street at lights, not just at the track. They are especially fun when you know your tires are bald and your ready for a new set...I've seen some pretty amazing videos of guys performing smoke shows
Our kits are NOT new...we've been manufacturing them since 1996, then started the LS1 kits when LS1's became available. As far as I'm aware, we are the original designers of this type of setup. As shown on our comparison chart, our kit contains additional circuitry and components which we feel is a necessity. You'll only find in the better kits to contain these features. Ours contain a remote (standalone) LED and MASTER arm switch in addition to the standard control switch.
As mentioned, when you’re not using the line lock; completely deactivating the circuit so accidental deployment doesn't occur is very important, not only for longevity reasons, but for safety reasons. Driving down the road, having someone switch the line lock switch and you not know it, then depressing the brakes and not being able to shut them off isn’t a good thing. I read recently a guy with an SLP kit recently deployed his line lock by accident while cleaning his car; obviously not a good thing as this is a quick way to burn out the solenoid (I believe he was having problems after this occurrence also…probably burned the solenoid out). Line lock solenoids should never be activated for more then 60 seconds as they can overheat. ALL our kits have rebuildable solenoids btw.
We fully warranty and support all products we design/manufacture; tech support is available for questions regarding our products/installs etc.
Hope this information is helpful to some.
Our kits are ALWAYS in stock and ready to ship!
Steve
Pres.
i never ran one really until this season, wish i had done one a long time ago.
it is much easier on your brakes and also on your posi unit if you have a stock rearend..lot of long brake tq's puts a lot of un needed stress on an already weak POS 10 bolt.
Steve
Pres.
Steve
Do you do installs? I am in the Pittsburgh area and would be very interested if you did the installs.
I may run it Friday without it, I just won't be able to cook the rubber before runnin'.
Then next week, I'll be placing an order with the guy who posted above
BTW, everyone I see with Nitto DR's heat 'em up good.
I guess I'll find out myself, since I will run Friday without a lock and a light burnout, and will run later this month with a lock/heavy burnout with Nitto Dr's.
But
If you wire it up SLP's way you wire it up so the switch grounds the solenoid and the wire from the solenoid to the swith shorts out somewhere the line lock will turn on. As Steve said that us a very dangerous thing to happen when driving the car - you will not have front brakes if the solenoid is energized. It needs to be wired with the switch powering the solenoid, that way if the wire to the switch shorts out it blows a fuse and doesnt acivate the solenoid.
You really done NEED one but with an M6 car it makes the burnouts a lot less stressful, an auto car will just brake dust up the wheels aftr a dozen burnouts. They also come in handy on a M6 car if the starting line isnt flat or your clutch drags a little to keep the car from rolling out of the lights.
