What's wrong with my car?
Need to know: suspension, tuning, transmission (clutch type or stall), tires, where do you run - weather conditions, etc.
You can make all the power you want, but if you can't put it to the track, it isn't worth ****. If you are making 400+rwhp, street tires are not the answer. Your steal D/S will not kill you times that much. With that much hp, and if you have suspension set-up, with the right tires, you should be in the low 11's. My SS is over weight with basically you set up - times are in my signature.
David
IMO the 1/4 time/mph is seriously influenced by the 1st 60'.
Try various launch rmp's. Don't "baby" it out of the hole. On launch don't just ease it out, dump it. You sound as though you have the rear-end and clutch to hold a 5000+ launch. Tires is another problem. Until you get some good DR (poss MT new ones) or slicks, you'll not get the 60' you are looking for. Try to get Harlan's 2-step to help out in the launch.
What are you shifting at? With heads/cam you should be able to shift at least 6500.
Practice. Vary your tire pressure and launch rmp. Don't assume that because you spin out of the hole you need to lower your launch rmp, try lowing your tire pressure. And get some good suspension parts. Going fast cost out the *** so try not to go cheap.
Hope this helps some. Your DA and/or DS is not the big culprit here. IMO its your tires and suspension.
David
Look at my suspension set up (go to my site). The SS doesn't see any street duty any longer (mainly due to the exhaust and spool).
Make sure you have SFC, a good adjustable TA, PHR, get a good set of shocks (mine are QA1 but there are other just as good out there), a better rear sway bar. Oh yea if you haven't already dump the front sway bar (at least for track use).
Good luck
David
