Camaro owners without bumper supports... come in (aero related)
9 Second Club NA
So what exactly are you doing to cover these holes? If the proof is there, then I'd like to handle this issue too. I havent performed any testing of my own whether these holes affect my aerodynamics, track times, mph, etc., but if one can, then its enough proof for me! Would like to see pics of what you used, how you did it, etc. Thanks.
Originally Posted by HumpinSS
Aside from the drag it sounds like DFCO (deceleration fuel cut off)
![Shiner](https://ls1tech.com/forums/images/smilies2/shiner.gif)
Originally Posted by gomer
I'm totally convinced that it is my piece of **** howling *** broke dick moser 12 boltthat's causing most of my problems with rolling resistance. I'm having it rebuilt this weekend and will try the testing again next week.
My car is an M6, witht he front bumper support removed. On a steady mild downgrade on a local freeway ( About 2 Miles - 134 Freeway between Figueroa and the 2 fwy) starting at 65 the car will get to 90+mph if i don't pay attention. (Would probably go faster if i didn't get on the breaks) This is my normal route home from Irwindale Speedway and I usually throw it into neutral by this point to take a break from the howling rear end.
IMHO I don't think it has much to do with your rear end. Are you sure when he rear was installed the rear break calipers weren't cranked down to far? With the car jacked up, how easily do the rear tires spin? If they don't spin all that well when the breaks are cold, after driving a distance and putting heat into the breaks, that may increase the rolling resistance.
Good luck, I hope you find your problem.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Check out some pics at www.imageevent.com/lastws6 I can not link the pic from work. search around for it. I have a couple pics of a mini cage for my front bumper support.
looks nice.
#35
Tyson did both my cage and front bumper support. He is a sponser at www.easternfbody.com performance auto fabrcation
does damned good work.
