Info for rebuilding Hal shocks + upgrading to Type "R" series
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
For anyone interested.
http://www.naake.com/qa1shockservice.html
Naake is an authorized QA1 rebuild center and I just talked with them on the phone. They rebuild the Hal shocks for 45 ea and will upgrade them to "R" series for $13 ea additional
1-2 day turnaround
1-2 day turnaround
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Originally Posted by Nine Ball
What is the "R" upgrade?
If you set the "R" shocks to 1 the front end will come up quickly but will compress as if it was set to the stiffest adjustment.
The standard shocks set to 1 will raise the front end quick but compress just as quickly. I believe this is why some people on the board have complained that the front end of their car would bounce after lauch with a set of standard HAL 12 ways.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
LS1Tech Co-Founder
The R series don't bounce as much Tony when you have the shocks real loose. Magnus has them for example, and the front end does not bounce. So even if he has the fronts at 1/1 the nose stays up. I might get mine redone over the winter now.
Restricted User
I also have had the R since their release, very nice shock. I havent had a problem with the fronts coming down and breaking anything...yet, but I only get them a few inches off the ground.
Good to know where to get them rebuilt at. Good find.
I was delayed in getting them out. I got sick the day I wanted to do it...
anyhow...I fedex'ed them out last night. since i'm cheap...I sent them out ground...will probably take 2-3 weeks by the time I get them back
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
