help with 1-8th mile dragracing gear choice
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I am trying to pick a gear for dragracing my 98 Camaro A4 I would like some opinions on which gear to use. The car is not driven on the street at all I race 1-8th mile only. which gear would be faster with these mods 3.73 or 4.11 and if you had to guess what do you think it might run with either one in the 8th mile. gas milage is not an issue
Ok here are my mods
free mods
mail order tune texas speed
lid
Z06 MAF
TSP 231 237
918 springs
LS6 intake no egr.
Pacesetter LT with the short bullet mufflers with no cats and true duel.
TCI 3500 converter
HAL R shocks
26" ET streets
race weight stock -250 weight reuduction +230 driver
solid motor mounts
poly trans mount
LCA's
Ok here are my mods
free mods
lid
Z06 MAF
TSP 231 237
918 springs
LS6 intake no egr.
TCI 3500 converter
HAL R shocks
26" ET streets
solid motor mounts
poly trans mount
LCA's
Those ET streets are going to be the limiting factor for gear choice. Are you able to run a 26x10 ET drag? Are you running a DOT tire limited class?
If you can run a proper slick (26x10) I would consider a 4.88 gear if you aren't revving the ***** out of it
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
