Drag Racing Tech
Should I get solid motor mounts?
Old Dec 31, 2004 | 06:44 PM
Torkman15's Avatar
10 Second Moderator
Default Should I get solid motor mounts?
I have a dent in my header where it was hitting my BMR K-Member. It was close but I didnt think my motor was twisting that much on hard launch with abundant traction at the track. It was so now what? I'm not doing the old-school short piece of chain trick. Can I buy solid mounts from anywhere?? I have been to BMR and Spohn etc, no luck. Any help would be appreciated. Thanks, Tom
Old Dec 31, 2004 | 07:38 PM
NLang's Avatar
You should try a set of poly mounts first. Afterward, if you feel there's too much movement under there with poly mounts, both Spohn and MADMAN make solid mounts. If you have access to a welder, they're pretty simple to make. Just two 3/16" plates and 1-1/4" OD .120" wall tubing with the factory pedistals and mounts being your templates. That'd save you the $130-150...
Old Dec 31, 2004 | 08:35 PM
Nate_Taufer's Avatar
you'd also need to run a poly trans mount if you're not already. I think i saw some on racenet. i cant recall their website. dont know if they are sponsors or not so i cant link it.
Nate
Old Jan 2, 2005 | 11:04 AM
Torkman15's Avatar
10 Second Moderator
Nate
I already have the trans mount, I figured that was enough since the motor just sat there rigid when I did my clutch and drill mod. Thanks, Tom
Old Jan 2, 2005 | 11:37 AM
Silent but Violent's Avatar
Torkman- I run solids and love them. They save ton of weight. I have my knock sensors deleted from my computer and absolutely no problems thus far. They actually take up alot less space. I'm running the pedastal mounts from spohn. Check out my webshots link for pics in sig!
Old Jan 4, 2005 | 02:49 AM
Dude silent but violent, that is the sickest living room i have ever seen...i have died and gone to bowtie heaven...can i sleep on your couch?
Nate
Old Jan 4, 2005 | 05:52 PM
Nate
LOL! The picture dosen't do it any justice. Its 8ft. wide! Even the Ford gang around here seemed to get a kick out of it. Glad you like. Chevy forever!
Old Jan 5, 2005 | 12:09 AM
No, really man...answer the question...can i sleep on your couch?
Old Jan 5, 2005 | 11:44 AM
I'm a loong way from Seattle but.......why not
