? about driveshaft loops
Most of the dsls replace the tunnel brace and only a couple look like they'd be strong enough to act as a tunnel brace and a dsl. The G2 looks like it would be the most sturdy. $120 is kinda hard to swallow though.
Am I worring too much about this? All of the dsl's should offer the same if not more bracing than the stock tunnel brace right?
Also, I'm a paranoid person, reading through the posts here I am seeing broken ds's and the thought of pole vaulting the rear of my car into the air makes me kinda uneasy. What choices do I have about putting a dsl at the rear of the ds? I was thinking about just having a loop welded torward the rear of the ta since the front dsl is only about 6" from the front of the ds.
Thanks.
But if the rear breaks, you'll only drag the driveshaft. And it will most likely fall out of the back of the transmission too, leaving it laying on the ground.
The driveshaft is 48" from u-joint to u-joint, which is definitely enough length to worry about pole vaulting, if it was to catch the pavement just right.
If it breaks behind the dsl, it will be a lot shorter, so it's very unlikely it would do anything except swing around to one side.
If you were to make a rear dsl, it would have to be a tall oval to allow the rear axle to move up and down.
I don't think they break at any other places than the welds.
