29.5" tire fitment
The Bull
Mike, you need to go in as far as you can. A 15x10 on a 5 will get it in far enough with the lower control arms fully offset to the inside. It will be extremely tight against the fender lip after that. Like what Chris showed, you may want to stretch the front edge of the fender 1.5". You do not need to stretch it both ways, but that's your choice. That will make the front edge of the wheel well flush with the inner wheel well and still look really nice. The thing that sucks is that it requires some body work and paint. I'm sure you could tuck it without doing that, but I wouldn't personally risk slashing the tire because it's awfully damn tight and huge. In comparison a 30" x 9" might not require near as much work and yield a very similar contact patch. The problem with the tire is really section width, not necessarily diameter.
Now, since I am going to a 29.5x10.5, I think the section width is less than on a 28W. Since I made room fro the 28W, will that allow the 29.5 to fit?
Here are some pics of my car when I did it. I cut 1.5in in the front and rear. I massaged the inner fenders pretty heavily but I am sure you already did that for your Wtire. I do however believe that the 10.5W tire with a 12in contact patch will hook better then the 29.5 tire with a 10.3in contact patch even with more rollout.
LS1TECH Sponsor
I cut front and rear fenders so they go straigth down...
I cut the whole bump stop bracket out..
I cut the front inner corner out, almost boxing it.. but I just cut as much as I could without welding and then pounded it with a hammer.
Get a really big hammer and pound in everywhere just for fun too.
