Drag Racing Tech
Spindle Mount front wheels...
Old Jan 22, 2005 | 10:26 PM
Brady's Avatar
LS1Tech Sponsor
Default Spindle Mount front wheels...
Who's done it, I think Rick's car has spindle mounts, but I"m not sure..
Anyone know what needs to be done?
thanks
...Brady
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Jan 23, 2005 | 12:15 AM
Billingsley Racing's Avatar
thanks
...Brady
This is not a spindle mount, but I think you'll get the idea what it will take. This is our new bolt in kit that will be available shortly.
Attached Thumbnails Spindle Mount front wheels...-front-strut-1-002_edited.jpg
Old Jan 23, 2005 | 12:18 AM
Parker TX's Avatar
So thats what it looks like
Old Jan 23, 2005 | 12:19 AM
Parker TX's Avatar
MADMAN hookd Rick up with the spindle mounts, Im not 100% sure though.
Old Jan 23, 2005 | 08:27 AM
MADMAN's Avatar
LS1Tech Sponsor
Rick had some machine work to the spindle done. I'm sure he will get on here and explaine Brady.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 23, 2005 | 08:43 AM
Big Mike's Avatar
Can someone explain how a spindle mount works? Are there wheel studs in a spindle mount?
Old Jan 23, 2005 | 08:48 AM
MADMAN's Avatar
LS1Tech Sponsor
The brake rotor is bolted to the wheel. The wheel has the races for the bearings on the spindle. So in other words the big nut that holds the hub and bearings on a stock car now holds everything on a spindle mt.
__________________
225-343-9029
Old Jan 23, 2005 | 08:57 AM
Big Mike's Avatar
Now I understand! Thanks Madman!! Whats the benefit of a spindle mount?
Old Jan 23, 2005 | 08:58 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
My Firebird has em.
Old Jan 23, 2005 | 09:10 AM
MADMAN's Avatar
LS1Tech Sponsor
The wheel is lighter and the brakes. The down side is you only get a 2 piston caliper which on these heavy cars I dont think is enough brake.
__________________
225-343-9029
Old Jan 23, 2005 | 09:56 AM
11 & 7 Second Clubs
Yes, my car weighs 2400 with me in it versus 3400-3600 for Fbodies, plus mine is a tube chassis.
Old Jan 23, 2005 | 10:54 AM
427's Avatar
427
Brian,
Have you used the Strange spindle mount yet with the 1 piston floater caliper? Hope it works!
Kurt
Old Jan 23, 2005 | 11:56 AM
MADMAN's Avatar
LS1Tech Sponsor
That setup Kurt scares me on these heavy cars. We have put a set on a V6 comp car but it only weighed 1800lbs.
__________________
225-343-9029
Old Jan 23, 2005 | 10:12 PM
427's Avatar
427
We have it on a car that needs to weigh 3100 but I am planning on driving it slow. If I don't stop, will you help me pull it out of the sand even if its a LS1?
Kurt
Old Jan 23, 2005 | 10:19 PM
y2khawk's Avatar
*cough* 2 chutes *cough*
Old Jan 24, 2005 | 06:08 AM
MADMAN's Avatar
LS1Tech Sponsor
Yeah I will help Kurt but I will have to pull your LS1 with a FORD!!LOL
__________________
225-343-9029
Old Jan 24, 2005 | 10:10 AM
427's Avatar
427
I can live with that!
Kurt
Old Jan 24, 2005 | 10:54 AM
Big Rick's Avatar
To remain a stock style style suspension setup it has to be custom fab'd. No one makes a kit that will work. The billingsley setup looks to be just your average spindle mount strut. That setup was outlawed in Thunder due to the fact it is not the factory style front suspension because it removes the upper A-Arm. All I did was purchase a strange Spindle mount front brake kit and then had custom plates built to hold the caliper and still using the HAL F-body struts. You also need spindle mount front wheels. The other thing that is needed to be purchased is everything that comes in the Strange 4th Gen brake kit minus the rotor and Caliper. You use the spindle that comes with that kit. I can put a kit together for anyone who wants to do this setup.
Also this week I'm having a dual rear caliper bracket being made for the GM bolt pattern for a 9" or 12 bolt.
Old Jan 24, 2005 | 11:24 AM
427's Avatar
427
Rick,
We bought a bolt on kit from Strange recently. It may be a new number though.
Kurt
Old Jan 24, 2005 | 11:31 AM
Big Rick's Avatar
Originally Posted by 427
Rick,
Kurt
I told them what I did and how easy it was to do, maybe they stole my idea
