Drag Racing Tech
Attention---->!PS Delete procedures!!!
Old Apr 13, 2005 | 05:37 PM
  #41
tektrans's Avatar
Originally Posted by samiam
Without the pump, there is equal and opposite pressure and vacuum created by the piston/seals within the rack. Looping the lines together can be as simple as tieing the lines together with a plastic m/m connector and a few clamps. The reason behind this is so that fluid can transfer from one side of the rack to the other while keeping the seals lubricated so seal failure doesn't occur. Only problem with tieing the lines together is you cannot bleed air out of the lines. This can lead to failure of the seals overtime and spongy feeling in the rack from a mixture of air and fluid.
An easy alternative is to keep the reservoir and run both sides of the lines to the reservoir and keep it filled with fluid. This can be easily modified by using standard rubber lines (fluid approved) and run them to each nipple on the reservoir.
Fluid will easily transfer from one side of the rack to the other while purging any air within the system just it was setup stock. Your just removing the power assisted high-pressure introduced from the pump.
Yes but that means more weight, which is a main reason for removing the pump in the 1st place.
Old Apr 13, 2005 | 06:58 PM
  #42
Jake the SSnake's Avatar
Here is a pic from the bottom of my car there is slightly less contact with the water pump but not enough to matter. This is the only area where the belt routing changes the rest is self explanatory. And most auto part stores will let you exchange the belt if it doesn't fit for one that will.You can see the point where the bottom alt bolt was contacting the belt b4 i removed it.Sorry about the upside down pic
Old Apr 13, 2005 | 07:29 PM
  #43
oOoLy's Avatar
If i want to use the Manual Steering Rack should i delete the PS ?
Old Apr 13, 2006 | 05:58 PM
  #44
02Z28's Avatar
Yes!
Old May 3, 2006 | 04:05 PM
  #45
NemeSS's Avatar
so how do the cars drive on the street with out assited power steering
is it hard to turn the car on normal evryday driving?
Old May 3, 2006 | 05:25 PM
  #46
fastlt1's Avatar
Yelp, but you get use to it after awhile.
Old May 3, 2006 | 05:51 PM
  #47
With skinnies on the front I hardly notice it at all.With full size tires it kinda sucks mainly when you need to turn the wheel at a stop.
Old Aug 21, 2006 | 10:08 PM
  #48
shanev8's Avatar
is there a better pic of the belt routing?
