Anyone running an 8" converter?
if so, who's converter and why did you chose an 8" over a 9"?
Ken
Seriously, because it is less recipricating weight and allows the engine to spool up faster. Plus, these converters are specifically designed for bracket race cars (either full body or rail dragsters). Unfortunetly, we can't check the efficiency of it because it is a non lock up converter
, but who cares, it's a race car.
Lee
I just need a verter that will run 10.3's in the cam only form.
My rossler TH350 is on its way, with t-brake.. They recomended a 8" converter..
..I just want to know if the 8" will make my car go quicker than a 9".. and I'd like to hear from LS1 owners that were in similar situations and had to chose, and why they chose the way they did.
Need to crush the current cam only record.
So as far as ET goes.. I was running 10.90's with a best 60' of 1.42, when I only changed the converter I cut my short times dramatically. The car started cutting 1.36-1.38 60's consistantly. The better 60's as well as the higher shift extensions in 2nd and 3rd brought my car from 10.90s to the 10.60s NA.
In short.. if you want to run fast N/A do some research and find out where you want to trap your rpms, get a +5000 8" stall converter/tire/gear combo that will let you cross at peak rpms, cam only would be what 6900? etc
I found that when I put the 8" in my rear gear was too small and I was losing ET from a low shift extension. I changed the 4.30 to 4.73 that made a world of difference.
IMO a NA drag car = Light Weight Chassis/Good Suspension + Big Tires + Big Gears + Big Stall
Lee
Lee
I think this answers your question my brother.
Coach
maggie
For example, Lee has setups that are proven.. I would go off what he says more so than I would that does not do many setups like Lee and I.
you crack me up
