Installed Grant steering wheel today
Your resentment is obvious and you're starting to repeat yourself. Back on topic, IMO, Grant steering wheels reduce safety and are illegal.
Here's a pic of my Grant steering wheel. PSJ I didn't have to use a spacer but did cut a very little off the column cover to keep it from rubbing (just used a razor knife). Oh yeah, cut the wires also. One other note, I found a steering wheel adapter at Discount Auto Parts that was real inexpensive.
Also dont put washers between the hub and steering shaft, there is a slight taper to the splines and the wheel may loosen up after a while. I just cut down the 'bell' on the horn kit (if you may put the stock wheel back on one day) or take a dremel to plastic upper column and trim it where it rubs.
Here is a pic of my 49.00 APC wheel/horn kit from autozone
Ya I just copied it to paint and shrunk and rotated it myself haha. I like the carbon fiber dash too. Where'd u get that at? Custom made insert?
it's in the shop all the time
Right John
Wait for it...
Me either.
Weight drop is pretty small.
