Drag Racing Tech
Two Step install on a M6?
Old Mar 15, 2005 | 06:55 AM
SlickVert's Avatar
Default Two Step install on a M6?
With switch are you splicing into on the clutch pedal for the activation wire?
The lower one that is primary use as a start switch that insure the clutch pedal is fully depress to allow engine starting or the top switch that is primary for disengaging the cruise control when the clutch pedal is depress a little?
Thanks
Old Mar 15, 2005 | 09:04 AM
1fastWS6's Avatar
top cruise control switch
Old Mar 15, 2005 | 09:25 AM
SlickVert's Avatar
Thanks that is what I thought
Old Mar 15, 2005 | 12:03 PM
Steve Burger's Avatar
LS1TECH Sponsor
White wire to the trunk release and the grey wire to pn 32 on the blue connector of the PCM. This pin is the clutch pedal wire.
