Drag Racing Tech
Kirkey mounting pics
Old Apr 12, 2005 | 09:04 AM
S_J_H's Avatar
Default Kirkey mounting pics
Thought I would share how I went about mounting my seats.
I built frames that mount to the stock studs out of mild steel square tubing.
Built in a crotch strap bracket on the drivers side frame.
The frames are very rigid and weigh 2.75lbs each.
I used Kirkey floor mount brackets that mount to the frames that allows adjustability.
Jegs back braces with longer roll bar tabs I made.
I have the seats mounted a bit lower than stock seat height, but Helmet to rollbar clearance is still not NHRA legal.
These cars just don't have a high enough roof line IMO to meet NHRA specs and still allow a good seating position. At least for my dwarf height of 5'9" .
Steve
Old Apr 12, 2005 | 06:15 PM
93LS1RX7's Avatar
Are you sure your door bar is legal?
Old Apr 12, 2005 | 06:27 PM
S_J_H's Avatar
It's a Wolfe roll bar I put in this car about 5 years ago. Nah it is not technically legal but I have never been questioned about it yet.
If it became an issue I'll cut it off and weld a straight bar in. No biggy to me.
Steve
Old Apr 12, 2005 | 06:36 PM
JS's Avatar
JS
Not too bad but now your seats weigh as much as a non power stocker
Just kiddin,they look nice...
Old Apr 12, 2005 | 09:00 PM
S_J_H's Avatar
I'm not that worried about saving every ounce like some of you guys. I'll just add more power if I need it . But I wanted a nice light strong seat setup that also looks good. The stock TA seats weighed in at just under 90lbs for the pair.
A single non power seat out of a f-body may be light and is a good budget method, but it is also fugly.
Anyhow, each seat with every mounting part,nut and bolt plus cover is 18.5lbs.
That's still pretty darn light.
Steve
Old Apr 12, 2005 | 09:12 PM
JeffT's Avatar
nice looking set up SJH and at 18.5lbs it's still over 5lbs lighter than a non power stocker.
Old Apr 13, 2005 | 06:20 AM
SlickVert's Avatar
Nice Job!
Old Apr 13, 2005 | 07:02 AM
next's Avatar
Looks great Steve. I know what you mean about the head clearance and that's part of the reason why I made mine the way I did.
Old Apr 13, 2005 | 09:06 AM
Birdie2000's Avatar
Looks real good, what are the specs about helmet placement?
Old Apr 13, 2005 | 06:14 PM
S_J_H's Avatar
The helmet should be 3" from the top off the rollbar. Not going to happen for most of us unless you sit on the floor. Some NHRA rules you just have to try and conform as best you can and meet the spirit of the rule. IMO these cars have a problem with this rule for most drivers. The roof line is low and you have a big long hood and cowl you need to see over.
Steve
Old Apr 13, 2005 | 07:47 PM
PRAY HRD's Avatar
what's the width of those seats? looks nice.
Old Apr 14, 2005 | 08:27 AM
Birdie2000's Avatar
Where does it state that they want a minimum distance from the cage? From the looks of that pic, it seems the closer the better...
Old Apr 14, 2005 | 08:54 AM
S_J_H's Avatar
it's in the rule book. NHRA and IHRA state the same distances.
A 16" for my side and a 17" for pass side.
17" was a bit loose for me but 16" a bit tight. I just used a jack and a couple blocks of wood to open up my 16" for a custom fit.
Steve
