Drag Racing Tech
GUYS WITH MINI-TUBS INSIDE(interior question's)------>
Old Apr 12, 2005 | 09:23 PM
FASTFATBOY's Avatar
Default GUYS WITH MINI-TUBS INSIDE(interior question's)------>
How did you guys make the interior panels fit? Mine are not even close, I see many hours with a heatgun to make them even remotely go back in the car(94 Z28) Back seat has been deleted, any thoughts, pics etc.....
Thanks
David
Old Apr 13, 2005 | 06:25 AM
MADMAN's Avatar
LS1Tech Sponsor
My tubs fit under my factory panels.
__________________
www.madmanandcoracing.com
225-343-9029
Old Apr 13, 2005 | 09:11 AM
Birdie2000's Avatar
Haven't done it myself, but I've seen several where the panels were trimmed to fit.
Old Apr 13, 2005 | 01:40 PM
Outlaw's Avatar
Any chance of you mini tub guys taking some photos and showing us how your setups are done? I know I for one would like to see them.
Old Apr 13, 2005 | 07:49 PM
PRAY HRD's Avatar
me too........especially if it's a convertible.
Old Apr 13, 2005 | 08:11 PM
Matt D's Avatar
Retired Street Racer
me too
Old Apr 13, 2005 | 09:07 PM
Brady's Avatar
LS1Tech Sponsor
Originally Posted by mdblackz28
me too
here's my small tubs, I'll get some more pics this weekend.
http://outlawdragradial.com/minitub
It dropped the rear end about 2" and helped the stability of the car out tremendously.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Apr 13, 2005 | 10:24 PM
PRAY HRD's Avatar
hey Brady, what did you do as far as the phb mount on the pass. side? did you relocate it or what? on mine, it is a major hinderance to fitting my tire/rim pkg. with the new rear i've got that's narrowed 2"/side. any help would be very much appreciated.
thanks,
Dave
Old Apr 14, 2005 | 01:59 AM
Outlaw's Avatar
Brady, I have to give you props, that car looks sick with the DR on it in that picture.
Old Apr 14, 2005 | 05:21 AM
Brady's Avatar
LS1Tech Sponsor
Dave, I don't remember doing anything there, but I'll double check. My rear is narrowed 2.5" per side and I have 6" backspaced magnum drags. This combo makes the wheels tuck 1" per side. I have offset LCA's and I had to trim the LCA relocation brackets at the bottom to clear the wheels.
Thanks Dave.
__________________
2016 Z07 Carbon
Old Apr 14, 2005 | 07:42 AM
PRAY HRD's Avatar
Thanks Dave.
yea i have the offsets too that move the lca's inboard like 3/4" on each side vs. the factory location. i know with the minitub it'll fit the well right, but the phb mount seems like it will be a challenge and i don't think my wheels will be in quite as much as yours are. i'm running a 15x11 with 6.5" bs and a 325/50/15 for now and then up to 30's when the turbos find their way on the car over the winter. tia for taking a look at it.
Old Apr 19, 2005 | 08:01 AM
Brady's Avatar
LS1Tech Sponsor
http://outlawdragradial.com/minicooler
-20an radiator hoses are on the way
__________________
2016 Z07 Carbon
Old Apr 19, 2005 | 08:52 AM
gator's 99TA's Avatar
brady that car looks tremendous!
Old Apr 21, 2005 | 09:32 AM
FASTFATBOY's Avatar
THAT POS...please.... Just kiddin Brady, your car gives me a woody, just dont tell Shannon. I heard you been contacted from a foreign country....please don't do it...FOR GODS SAKE..you will be doing this
David
Old Apr 24, 2005 | 04:18 PM
Stone0fFire's Avatar
i am very interested in running a setup like brady's
but i see he has an LT1
what difference does it make?
i like the idea of running 315/60/15 drag radials
and i really really like the magnum drags
im trying to get the plan totaled before i start buying things
car is stock now.
well. back there, anyway.
Old Apr 24, 2005 | 06:59 PM
FASTFATBOY's Avatar
car is stock now.
You need a LOT of power to take advantage of the 315/60 like Brady has...ALOT, You can go low 9's on a 325/50 which is why me and my Dad are mini-tubbing the 94 we are doing....I have pics...will put them up later. But I can tell you, it is not a small task. It requires alot of tools.
David
Old Apr 24, 2005 | 07:11 PM
xxx's Avatar
xxx
David
Did I hear woody??? Dave don't cry about the car just come up with 40k and it could be yours
Old Apr 25, 2005 | 06:29 AM
BTL FED's Avatar
David
https://ls1tech.com/forums/drag-racing-tech/309476-finally-finished-minitubbing-project.html
For My Mini-tubs I used:
Plasma Cutter
4.5 Grinder with Cutoff Wheel and Grinding Wheel
Air Hammer
Drill
Big Hammer
Mig Welder
Rivets
Air Sheers (To make new Tubs)
Old Apr 27, 2005 | 10:00 AM
FASTFATBOY's Avatar
Originally Posted by BTL FED
https://ls1tech.com/forums/showthread.php?t=309476
Plasma Cutter
Air Hammer
Drill
Big Hammer
Mig Welder
Rivets
You forgot:
Carpenter square
Various sharpie markers
Seam sealer
Respirator
Air nibbler
Die grinder
Air compressor
Posterboard(for mock up)
Magnets(to hold it all in place while fitting)
Bottle of Excedrin(you will need it)
Just something totally un natural about cutting up a perfectly good car LOL
David
Old Apr 27, 2005 | 10:05 AM
Birdie2000's Avatar
And you always realize just how unnatural it is the first time you **** up.
