Drag Racing Tech
Shift Point Question
Old May 6, 2005 | 07:00 PM
Travisimo's Avatar
Default Shift Point Question
During a drag race, what is the best RPM to shift at on a mostly stock LS1 M6 F-body. I have heard about 5,700 but wasn't sure. I have been known to shift a little early to avoid that damn rev limiter. (such an awful sound)
Old May 6, 2005 | 09:11 PM
gator's 99TA's Avatar
6300-6400 is what i have found optimally. but ofcourse you need some custom tuning to achieve that. otherwise as high as possible. whoever told you 5700 was misinformed.
Old May 6, 2005 | 09:15 PM
black_ws6's Avatar
Put it on a dyno and see where you start to drop power and shift there with a shift light or aftermarket tach to be certain. Otherwise, shift by feel cause the stock tach is not very accurate.
Old May 7, 2005 | 12:47 AM
snake charmer's Avatar
a dyno will help you find where your car shifts best
Old May 7, 2005 | 11:33 AM
guys this is a mostly stock ls1. sure you can put it on a dyno but i bet he will go fastest shifting 6200-6400 rpms.
btw, you want to shift after your powerband starts to fall. this allows you to pick up the next gear closer to that powerband.
Old May 7, 2005 | 04:05 PM
Travisimo's Avatar
Thanks for the tips, I knew I was shifting a little early. I want to get a monster tach and get the rev limiter removed with a tuner sometime soon.
Old May 7, 2005 | 07:55 PM
black_ws6's Avatar
Don't remove the limiter. Just get it bumped up a bit. It's always nice to have it if you need it.
Old May 7, 2005 | 08:39 PM
Travisimo's Avatar
To about 6,500?
Old May 8, 2005 | 07:37 AM
black_ws6's Avatar
To about 6,500?
That should be pretty safe. I am at 6800, but I have comp 918 springs that can handle the extra RPM.
