What is the fastest rod bolts, rings, and bearings car?
this is all rediculous.... i mean hell cam only list all of them swapped springs and retainers ect.. and pushrods, some of them maybe even shaft mounted rockers ect... uh oh... i think we should all get a big DQ lol
SUX2BU... heres what you need to do.. swap out those damn forsaken rodbolts so you can be bolt on again, and freakin take that record to shut some of these ppl's up! i feel for you man, sounds like you gots a fast car that should be recognized.
You wont find any lighter tension rings hen what these come with stock, why do you think the hone still shows up fin on 100K motors - some kind of space age cast iron liner that never wears
Ask the guys that use a quart of oil every 2000 miles if they want lighter rings ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Sure you can do a nicer balance job then stock, sure you can loosen up the bearing clearances a little, sure you square everything up and 'blueprint' it. But I cant see how that will help as much as 1.8 rockers, stronger valve springs, milled 241 heads with very nice valve jobs,LSX intakes etc and no one seems to bitch about that.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by SUX2BU
Yeah i was gouing to blur it out but i didn't want the ****'s to say it wasn't the stock receipt cause it was altered. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by LS1_PNYTAMR
damn if i had the money and you had the time id pay to put it back stock in there minds and watch you whoop some ***.. if u beat 10.98 ur the fastest SI car in my opinion and a lot of other ppls opinions too.. we got about 10ppl from my local board who are pretty upset and think rodbolts dq'ing you if u run the # is bullshit ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
like i said.. no way ur running 10.48... but oh well.. the cam only boys are going 10.32 and there is only 2 of them doing it.
at any rate.... lsx intakes touch oil.... pull of ur intake after u drive ur car and tell me there is no oil?? so i guess silenty but violent owns the si record with the stock ls1 intake on his 98 z28 correct?
