Drag Racing Tech
A few launch questions....
Old Jul 17, 2005 | 12:21 PM
kevredz's Avatar
Default A few launch questions....
I am currently on 26x10.5-16 ET streets running 1.61-1.63 60fts launching from an idle without any tire spin (on a prepped track). I am wanting to use my t-brake, but when I do the car just lights the tires up. I now have some 15" telstars and need suggestion on a good tire for them that would handle the t-brake with out dragging me down on the big end.
Old Jul 17, 2005 | 04:00 PM
sixpackmotorsports's Avatar
any suspension mods? id go with a taller tire also
Old Jul 17, 2005 | 05:20 PM
kevredz's Avatar
Not alot. I have 1LE rear parts (control arms, panhard Bar, sway bar), relocation brackets, WS6 front springs, removed front sway bar, Spohn body mount tq arm w/ spherical end, Spohn subframe connectors.
Why would I benefit from a taller tire? Wouldn't that create a higher gear ratio and slow me down?
Old Jul 17, 2005 | 05:42 PM
The LT1 That Could's Avatar
it would give u more gear, and ideally give u more MPH.
i would go with an ET Drag, or something similar....if youre blowing ET Streets away, step up to a softer tire, and see if that helps.
Old Jul 17, 2005 | 06:39 PM
kevredz's Avatar
I would go with an ET Drag, or something similar....if youre blowing ET Streets away, step up to a softer tire, and see if that helps.
I have tried a taller tire (28x9-15 Hoosiers) before and lost 2 tenths and 2mph in the 1/8th mile (haven't tried the 1/4). I think it was because either a) the taller tire wouldn't allow weight to transfer with it being so much taller in the rear causing slower 60ft's or b) the overall gear ratio was much higher, thus accelerating slower.
Am I the only one that experienced a ET loss from a taller tire?
Old Jul 17, 2005 | 08:20 PM
i would say that was the problem, but not totally sure. i may just be talking out of my ***, lol.
Old Jul 17, 2005 | 09:39 PM
kevredz's Avatar
LOL...
I wish I had as many slicks as my wife does shoes, then I could just try different ones until it ran the best.
Old Jul 18, 2005 | 03:27 AM
ChevyGoldfinger's Avatar
Litlle more info might be helpful.
a) What gear ratio are you currently using?
b) Still have the stock 10 bolt?
c) What shocks?/settings?
d) What stall? (Brand) (RPM) (STR if known)
e) Do you plan to run 1/8 mile only?
Sounds like you have a pretty serious motor/trans, you might need to go with some more serious suspension mods, and maybe a few other things, including a lower (higher numerical) gear ratio. Depends on your goals for the car, is it still daily driven, etc.
Old Jul 18, 2005 | 07:53 AM
kevredz's Avatar
a) I am running 3.73's
b) Still running the stock 10 bolt
c) Stock shocks (I put a set off an 02 ws6 because the 98's were wore out)
d) Edge Racing Converter (custom), 3800rpm stall, 2.45 STR
e) I run the 1/4 mile the most. 1/8 mile every once in a while.
I plan on staying N/A, and my car is drove on the street around 200-300 miles a month so I don't mind sacrificing driveability. I am crossing the 1/4 line at 121mph and taching around 6200-6300 rpms on the current setup. As for the converer, Jason at MTI drove the car and said the converter was a little on the tight side. Thanks for the help.
-Kevin
Old Jul 18, 2005 | 08:34 AM
12secSS's Avatar
A taller tire will not help you, unless you had nitrous out of the hole or turbo/supercharger. Those 1LE pieces are fine for Road Racing, but not for Drag Racing. I would get better aftermarket pieces. What do you run in the 1/4 mile? What is your burnout technique? I would not go to a bigger tire unless you have 4.10s or higher gears (numerically). The larger tire will cause your 3.73s to drop to (for example) 3.23 gears. The proper way to fix a traction problem is to fix the suspension, not just throw bigger tires on it. That is a band-aid fix.
Old Jul 18, 2005 | 09:53 AM
kevredz's Avatar
I bought the 1LE stuff a couple years ago just to replace the stock wore out bushings. Last time I went to the 1/4 I ran high 11.3's at 121 with 1.7 60fts (Full weight). I had the car re-tuned for the Th350 and the 2R heads, put fresh stock shocks, and skinnies on it then ran it again at Abilene 1/8th mile, and ran low 7.3's with low 1.6 60fts (which was a 2 tenth improvement for me at the Abilene track).
On my burnout, I roll through the water, start the burnout in 1st, shift to second, when I white smoke them (not very long) I roll out of it.
I can hook when I flash the converter, just not when I use the t-brake. I guess because of the fact that flashing pre-loads the suspension.
Old Jul 18, 2005 | 06:25 PM
kevredz's Avatar
Thanks for all the help.
