26" drag RADIALS to 28" slicks?
What should I expect with this change. I have a 12 bolt with 4.30's, lca's, spohn frame mounted ta, and relo brackets
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
The slicks won't be as stable at higher mph as the radials, so be careful staying in the groove and with steering in general. You'll also loose about 300-500 finish line rpm due to the 2" standard difference in tires and the fact that the slicks will grow at higher speeds whereas radials don't.
Derek
Derek
