Anyone use Slp line lock?
Also after u get done warming up the tires do u just turn the line lock off?
Don't think you can go wrong with either one.
Thanks for the recommendation. Our kits were produced before another manufacture decided to sell their own "exclusive" kit. Funny thing was their reps used to work with our vendors with our items...hmmm
Both kits will function well, I consider the other manufactures kit to be a bare-bones setup with safety concerns. Our kit retains additional benifits over theirs yet still priced competitivly. Our kits use a master arm switch with remote LED indicator to control the overall ciruit and a control switch when you want to activate the solenoid.
Without the master arm circuit, your line lock is always live and can be activated accidentally without knowledge. The other manufacture does not use a momentary switch OR a master arm switch to activate the line lock. You COULD switch it on by accident when you’re cleaning your car or a passenger switch it unaware of what he did. This can have bad consequences…at minimum line locks shouldn’t be activated for more then ~60 seconds, by doing so, can burn it out. At worst, an accident can evolve due to your brakes locking and staying locked when you don’t want them to.
The way our kit works is: when you want to use the line lock, switch the master circuit on, the LED will illuminate. Now the line lock is ready for operation at will. When you’re ready to stage, heat up your tires, the line lock solenoid can be activated by depressing the momentary button. When you’re done using the line lock, switch the master circuit off so the line lock is permanently deactivated. Accidental deployment cannot occur now.
Many folks whom have purchased another manufactures kit then realized this was an issue and added the additional circuitry necessary to include this feature. The additional cost of ~15-20.00 is not necessary with our kit as it includes everything.
Our kits are ALWAYS in stock and ready to ship w/in 24 hours M-F. I highly recommend the B-001 kits over the others due to the price point. All kits retain the same circuitry. The difference in pricing is solely due to the solenoid used. ALL our solenoids used are rebuildable, they all work equally well. I have yet to find a difference in feeling from one to the other. We offere them with different solenoid configuations for the folks whom "have to have" one style over another.
We offer the B-001 kits in two configurations, one a top mount and the other the front mount. The front mount is the original design, the top mount was produced since it is a much easier install due to the LS1 power block location. Drilling to mount the solenoid can be difficult in comparison to the top mount setup. The front mount kit locates the solenoid behind the power block. THe top mount kit locates the solenoid right next to the grounding bolt located on the top of the front fender (almost right above the front mount location).
Steve
