School me on anti roll bars please
If I were to do it over I wouldnt do another 'factory' style bar though and would do a Wolfe or something similar. Problem with the Spohn bar is it sits right against the shocks so a DA shock with ***** on both sides or just larger diameter wont fit. The BMR bar is bent around the shocks a little so its probably a little better then the Spohn in that respect but a Wolfe or other 'real' race bar would be the best solution IMO, especially if you plan on narrowing things up in the rear. I ended up making some offset bushings to move the Afco shocks to the outside but now they are pretty close to the LCAs and the **** just touches them - I'm just about to bolt the stock rear shocks back on..
http://s97997631.onlinehome.us/temp/...h%20launch.jpg
I run the Spohn drag bar, and it's just a little tighter feeling than stock around corners or up slight inclines. My friend has gone 1.32's with his (Magnus).
So what's it going to be?
BMR
Spohn
Wolfe
The car is 80% track and 20% street... on the street I just cruise with the car... no crazy handling manoevers
Your avatar is freaking me out man.
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
The wolfe is a little noisier on the street but I would say the anti roll characteristics of the wolfe single, BMR and Spohn is probably similar - the 1 5/16" solid spohn bar doesnt deflect much I'm sure.
im calling BULL ****
I've lifted for several years and know several guys (whom i lift with) that have trained and won several body building divisions.
for you to change like that from '02 - '03 is almost nearly impossible...
it takes body builders alone about 20weeks to get ready for a body building show.... and for you to get bulky and ripped like that after coming from the 2002 picture is bull ****...
I'm sorry if it sounds harsh but if you really did that then go do some shows because no body else in the world can change that fast in one year
