Drag Racing Tech
how safe is it to remove front + rear bumper support?
Old Aug 29, 2005 | 03:15 PM
SOM98TA's Avatar
Default how safe is it to remove front + rear bumper support?
I drive the car.. daily.. I removed just simple things... spare tire + jack but I heard you can drop 50ish lbs from removing bumper supports...
would it be really unsafe to do this? I want my car to hold up in a crash.. but I really want that extra 50lbs off... would it completely kill the safety to where a 40mph accident is lethal?
I dont care if its past 100ishmph on the street I dont drive that fast..
Old Aug 29, 2005 | 04:12 PM
GM Muscle's Avatar
I wouldn't remove the rear impact bar on a street car, not much between the bumper and gas tank without it. As for the front, I think you'd be fine unless you hit a pole or tree dead center.
Old Aug 29, 2005 | 04:29 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Those supports are there for a reason. Use a little common sense when you ask if removing bumper supports is safe, hahaha.
I've seen cars nearly totalled WITH the supports in a slow 30 mph crash. I'd be scared to see how badly they rip apart without the bumpers intact. You might find an LS1 in your lap, or a fuel tank on your head. OUCH
Old Aug 29, 2005 | 05:08 PM
SPANKY LS1's Avatar
I wouldn't do it on a street driven car, too much risk. You may be able to control your driving, but you can't control someone from rearending you or worse.
Old Aug 29, 2005 | 08:53 PM
al's Avatar
al
I got 29lbs. off the front including the washer fluid res. and paneling. I`m removing the rear next Sat. Don`t forget the side impact bars. They were 17 lbs. for the both of them including the insulation and bolts.
Old Aug 29, 2005 | 09:28 PM
libertine1015's Avatar
Not safe for a car that sees street use but most of us dont run the front anyway. I have an aluminum I/C (frontal energy diffuser) instead
Old Aug 29, 2005 | 10:02 PM
sleeperstyle's Avatar
good luck getting the front cover off. i got most of the bolts off, then gave up where the cover fastens to the fender for fear of damaging the looks of my nice car just to shed the bumper support.
im thinking you have to actually take the fenders off to get the cover off, which i don't think i'll do.
Old Aug 29, 2005 | 10:13 PM
Carbed4thGen's Avatar
WRONG! LOL not tryin to be mean. Just look a bit more it takes like 10 mins to get that cover off!
Old Aug 29, 2005 | 11:14 PM
Loudmouth LS1's Avatar
You think you could give me a walkthrough? I'd like to pull that front bumper support off, just haven't gotten around to it yet, but a walkthrough would make it a lot easier and i'd probably do it my next day off, which is thursday!
Old Aug 30, 2005 | 06:31 AM
GM Muscle's Avatar
It's simple. In a quick nut shell, go under the car and pull all the little (7mm?) bolts out of the plastic and the 3 push clips in the back center (they are tucked up good. Then go up top, pull the upper support and healights. Then on each side there is a total of 3 nuts and 1 bolt, the bolt is at the front of teh fender facing out (can't miss it), and the three nuts are along the bottom edge of the fender. When you retighten the 10mm fender nuts, don't go to tight, if you do your seem will eventually become all wavy.
Then the foam is clipped to the impact bar and the impact bar itself is held on with 6 nuts.
Be very gentle with the cover, the paint will spider web very easily, it's nice to have another set of hands. If you do it yourself grab it front and center on the top and bottom.
Old Aug 30, 2005 | 07:34 AM
Thanks dude, and I don't have to worry about the cover, the damn thing is already spidered! Back in NY before I moved here while I was going to school some stupid *** ricer backed into it while I was parked and in class, came out to find my nose spider cracked scuffed in an upward motion (think he pretty much slid his rear bumper up the nose) and luckily his fart can didn't hit the car but had a 5 inch circle cut into my license plate (that's why i'm assuming it was a ricer)!
Old Aug 30, 2005 | 09:10 AM
It takes 10 Min the second time you do it!
Old Aug 30, 2005 | 09:43 AM
Haha its true its easier the second time. I rushed the first time and got it off in no time
Old Aug 30, 2005 | 01:44 PM
transam1998's Avatar
My 89 Conquest TSI was totalled in a 30mph crash. The front bumber of the car folded right up to the tires
I didn't even feel the impact.
Old Aug 30, 2005 | 06:02 PM
SUX2BU's Avatar
Safe is a relative term. i feel plenty safe in my 2980 lb daily driver. i took EVERYTHING out.
