What's this thing gonna run? 437.1/475.0
What are your guesses on this one - i'll give you as much info as I can. I will have new times Sunday.
Cardomain to see the mods.
Just dyno'd at 437.1rwhp 475.0 rwtq with a broken spark plug since fixed but I won't have new numbers until tomorrow night (Friday)
Track is Quaker City in Salem Ohio 1300ft elevation. I usually cut low 1.7's on drag radials @ 16lbs psi and run 12.6-12.8 @ 105-107mph in the Summer heat.
The track is slower than other in the area due to the finish line being 16' higher than the starting line - this incline starts to take place around the 1000' mark. Usually .2-.4 and 3-5mph slower than say Norwalk for instance.
Assuming I can somehow pull a 1.85-1.90 out of the car - what are your guesses?
Yeah I don't think i'll hook good tomorrow - not used to the blower yet - first time launching with it so i'm gonna have to relearn the car. Tough chore with no suspension other than LCA's and drag shocks with DR's. We'll see in a few hours I guess. Gates open at 9am and we have the track for 8hrs - plenty of time.
First pass was an easy one - 3/4 throttle just to make sure that it would hold - blew the pcv vent tube off of the pass valve cover and dumped about a quart of oil onto the header HUGE smoke screen. Took about 3 hours to fix cause we had to run out to the part store which is a good distance out - anyhow - got it fixed.
Next run was a full on run in eliminations - dialed in at 12.00 ??? Had no clue so:
RT: .580
60: 1.763
330: 4.904
1/8: 7.503
MPH: 94.98
1000: 9.677
1/4: 11.623
MPH: 121.47
Followed this up with 2 hotlapped runs of 11.88 & 11.70
Pretty good day since I was able to still drive the car home. At our other track that would run around 11.30's @ 124 or so.
Need a rear and suspension work to launch effectively.
RT: .580
60: 1.763
330: 4.904
1/8: 7.503
MPH: 94.98
1000: 9.677
1/4: 11.623
MPH: 121.47
Dam I never had that much time diff between Norwalk and Quaker. Either way your still cooking. Good job, now go to Norwalk and click off some 1.6's 60' gotta love the traction there.
My best 60' was at the Norwalk track rental - a 1.67 - I love that track
The difference I see is actually between Quaker and Dragway 42 - just used the Norwalk name because it's more popular.
1 more track rental at Norwalk this year - I want to get some drag seats in there and remove the passenger airbag - lose a little more weight.
BTW - all runs, and the 3475 race weight, were made with between 3/4 and a full tank of gas - something I never do. Usually it's 1/4 tank
