Drag Racing Tech
What robs more power?
Old Sep 9, 2005 | 10:36 AM
Carbed4thGen's Avatar
Default What robs more power?
So wat robs more power the 12-bolt or the 9-inch? Always wondered and never actually looked into it. So whats the answer to this?
Old Sep 9, 2005 | 10:54 AM
BlueSix's Avatar
There's more to it than just what size rear...posi, spool, gear ratio...etc.
Old Sep 9, 2005 | 11:18 AM
Ok so given the both have 35 spline axles, the same gear and a spool. Comparable axle sizes and such
Old Sep 9, 2005 | 11:26 AM
LOnSLO's Avatar
9" will lose more. It's a hypoid type gear, engaging more teeth at once on the pinion. I've had a couple 9" rears, and they both lost nearly 30rwhp compared to a 10 bolt. The 12 bolt will usually lose like 12 to 15.
Old Sep 9, 2005 | 11:41 AM
Bryan @ Speed Inc.'s Avatar
it's a trade off... 9" will eat up more power but will hold up to more power than a 12 bolt.
Old Sep 9, 2005 | 05:18 PM
mongse's Avatar
I ruin the end of films...
I switched to a 9" and figured I'd make up the lost hp by going w/ bigger turbos.
Old Sep 9, 2005 | 09:00 PM
LOL I have the 12-bolt in there now and already wanna change it (havent even ran the car yet) With plans of close to 1000 HP on the gun I was tryin to save some carnage
Old Sep 9, 2005 | 11:41 PM
mongse's Avatar
Same here. The 12-bolt wasn't going to handle what I've got cooking for it. Hopefully the 9" will. According to Moser, the 35-splines will work...barely.
Old Sep 10, 2005 | 06:26 PM
MADMAN's Avatar
LS1Tech Sponsor
Why not a 9" housing and a 12 bolt center section??
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 11, 2005 | 01:31 AM
Can u explain this cause I just got COMPLETELY confused. Wat part is each here? Maybe I'm just tired
Old Sep 13, 2005 | 01:20 PM
Ls1LikeNoOther's Avatar
like having a big bearing 12 bolt...9" bearings on the axle flanges on ur 12 bolt..
Old Sep 13, 2005 | 01:35 PM
MADMAN's Avatar
LS1Tech Sponsor
Strange makes a center section that will fit a 9" housing but uses 12 bolt gears.
__________________
225-343-9029
Old Sep 13, 2005 | 01:44 PM
Brandon Boomhauer's Avatar
Got a link to that madman?
What benifit is it though? I've thought he 12bolt was lighter, so whats the point of puting it in a heaver case? Whats the point of going with the center section, when the 9" holding point is more teeth touching the gear?
I've heard of a 12bolt with 9" bearings, but still unsure of what that really helps.
oh and didn't bigrick go 8s with 31 or 33 splines?
get 35+ spline/gun drilled for weight savings...
Old Sep 14, 2005 | 06:14 AM
MADMAN's Avatar
LS1Tech Sponsor
The 12 bolt takes less hp to turn. I dont have a link but Stranges part number is a PRG500.
Big Rick has a 9" and I have been screaming at him to get bigger axles.
__________________
225-343-9029
Old Sep 14, 2005 | 06:22 AM
jay_99z's Avatar
Madman, You sure that will work?
A friend of mine called Strange about that setup and it was not reccomended for an Fbod. Supposedly it's not as strong and is better for a very lightweight ride. Now.....this is what he was told. Do you know anyone that's actually running it? I had thought about that for mine at one time.
Old Sep 14, 2005 | 10:24 AM
MADMAN's Avatar
LS1Tech Sponsor
I wouldnt try it unless it was a N/A car. I was just giving options.
If you want a low drag 9" center section get the new Mark Williams unit.
__________________
225-343-9029
Old Sep 14, 2005 | 10:42 AM
Wat's the difference from a Mark Williams unit to say a Moser unit? and does Mark have a website?
Old Sep 14, 2005 | 10:58 AM
12secSS's Avatar
This is the best **** for drag racing, but you better have the $$$ to back it up. He has quality stuff and unless you plan on being a pro drag racer ...
http://markwilliams.com/
Old Sep 14, 2005 | 10:59 AM
silverZ98's Avatar
with stock rear and gears i made 420/391 in 60deg weather in november, with my set up i got now is a moser 9in with spool 35 splin gun drilled axles and 4.11 gears. i made 404/381 in 107geg heat (hottest day here this summer) so in my opion 16hp not a big loss for me and i think it will be even less in cooler weather. and i got a rear im not skeerd of breaking any more
Old Sep 14, 2005 | 11:11 AM
MADMAN's Avatar
LS1Tech Sponsor
www.markwilliams.com
The Mar Williams is about $2000.00 higher but the benefits are killer as far as weight and drag.
__________________
225-343-9029
