lugs for prostars
So your saying your using 3.25" wheel studs with closed end lug nuts???
If so that a big no no..... FYI at the track they want to see thread contact and the only ones allowed are open ended lugs nuts.... and that a good idea on the street if thats what your doing since what you think might be tight is just the lug bottoming out on the stud and is not really tight at all.
Kyle
how do you know... i'm running pro-stars w/ closed ended lugs. 7.5" b.s. and a 5.16" spacer. i haven't had problems and have had plenty of passes, burnouts, and street miles on them......... any thoughts???
also........ at the track, is tech not going to let me run if i have the closed ended??? i want to run at rt66 next season.
) The Best V8 Stories One Small Block at Time
