Drag Racing Tech
View Poll Results: Hood Pins or Not?
Add hood pins to the hood in the pictures below
24
61.54%
Leave the hood as it is, (no hood pins)
15
38.46%
Voters: 39. You may not vote on this poll
hood pins or not???
Old Sep 25, 2005 | 01:03 PM
Noyzee's Avatar
8 second mod
Thumbs up hood pins or not???
this is my hood, should i put hood pins in or what??
Old Sep 25, 2005 | 01:14 PM
LC's Avatar
LC
i say hood pins are ugly.. but as long as you be safe...
Old Sep 25, 2005 | 01:22 PM
Noyzee's Avatar
8 second mod
i think they are iffy. i only want them so i can remove all the hood latch and cables ect ect. mainly for weight.
ps, how can i make this a poll?
Old Sep 25, 2005 | 01:23 PM
SPANKY LS1's Avatar
If you're going to leave it as a bolt on hood, I'd definitely put at least two in the front, one on each side. It is cheap insurance from the hood flying up, especially on a car that sees alot of strip duty as yours does.
If you're going to remove the hinges and struts and make it more of a pin on hood, I'd do Dzus fasteners before I did hood pins, they look MUCH better.
Noyzee's Avatar
8 second mod
also thought about those fance fastners.
anyone have pics of these cars with hood pins?
Old Sep 25, 2005 | 01:38 PM
SPANKY LS1's Avatar
Here you go, this should help you visualize them better.
Old Sep 25, 2005 | 01:39 PM
Noyzee's Avatar
8 second mod
sweet thanks. i dont think dzus will fit. those look great tho.
my hood is finished top and bottom.
i was foing to leave the hinges and struts, just remove the hooks on the hood, and the latch, leaver, and cable.
Old Sep 25, 2005 | 01:40 PM
Noyzee's Avatar
8 second mod
thats pretty good. haha.
show me with just 2 pins up front
Old Sep 25, 2005 | 01:47 PM
GM Muscle's Avatar
Brad I would atleast do the front. I'm working with ASCD right now on a hood that is basicly a pin on with hinges at the back and one strut mount.
I'm sure if you eliminated the front latch you could easily remove some weight from the hood itself too.
Old Sep 25, 2005 | 01:52 PM
Noyzee's Avatar
8 second mod
i just hate to drill my hood, then find out i dont like it.
i dont want another hood, but i think i could find 5 pounds + going to pins
Old Sep 25, 2005 | 02:46 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Or get a new lightweight hood from VFN, and use pins on the front for it. How much does your hood weigh, 50 lbs?
The big reason I switched from my ASCD WS6 hood to the VFN WS6 hood I helped them make was to go from a 47 lb hood to a 25 lb hood. Still using hinges and latch.
Old Sep 25, 2005 | 03:37 PM
Noyzee's Avatar
8 second mod
john, i realy like my hood. it is heavy, but worth the weight.
Old Sep 25, 2005 | 04:25 PM
mongse's Avatar
I ruin the end of films...
That's what I did. I'm using two hood pins in the front for the street car, Dzus rails for the race car.
Old Sep 25, 2005 | 04:34 PM
Little G's Avatar
I dropped 10lbs, but that included hole sawing the hood frame.
g
Old Sep 25, 2005 | 05:08 PM
monsterls1's Avatar
I was a little weary to put mine in, after paying $500 for the hood and another $600 for the paint job. But I went ahead and did itanyway and I think it looks great,i just did the two in the front. No pics yet the car is in "the shop"!
Old Sep 25, 2005 | 05:26 PM
Reckless's Avatar
Super Moderator
Did it a couple years ago on my car.....dropped 5 pounds off the nose.
Old Sep 25, 2005 | 05:32 PM
Big Mike's Avatar
Brad, I made the poll for you!
As for me, I would add dzus fasteners all around the hood and get rid of the hinges and locking mechanism to optimize the weight savings!
Old Sep 26, 2005 | 02:26 AM
CAT3's Avatar
Restricted User
Brad, cant you see yourself getting to like another hood? VFN might work with you on making one like yours, either FG bolt on weighing ~20lbs (~30lbs lighter than your current) or CF which would be killer. Good luck.
Charlie
Old Sep 26, 2005 | 03:28 AM
02 BLK WS6's Avatar
Hood pins only if you get a super lightweight fiberglass hood and you are going to lift it off to work on car. Keep the sleeper look and NO HOOD PINS. just my .02
Old Sep 26, 2005 | 07:19 AM
Noyzee's Avatar
8 second mod
thanks mike.
my issue is the dzus wont rit my hood, its to thick (i think)
also, i like the hood, and opening it, dont think i want to remove it everytime, thats easy acces for damaging the paint ect.
i will see what vfn says, but i know they take for ever!
plus the hood now is to nice, the under side is so sweet, and the finish is mint. i think id rather just save the 5 pounds loosing the latches ect, and keep it nice.
but keep the info coming. and maybe some one can fill me in if dzus will work? i could put them up front, and maybe 2 on the sides, and leave the hinges.
