Drag Racing Tech
Th400 Scatter Shield
Old Oct 5, 2005 | 10:05 PM
xssive's Avatar
Default Th400 Scatter Shield
Has anyone used a metal scatter shield without having to beat the snot out of the trans tunnel? I want to use a Hughes or CSR scatter shield to protect against an exploding drum, and I dont want to pay 300$ for the Supershield or whatever.
Old Oct 5, 2005 | 10:15 PM
Navy David SS's Avatar
None will fit our car and a TH400. I have tried. Just buy the SFI certified bell housing.
David
Old Oct 5, 2005 | 10:24 PM
xssive's Avatar
The bellhousing is nice, but that doesnt protect against drum failues, just felxplate failures.
BTW, can I cut the th400 housing for the ultrabell after the tranny is built? I just got one delivered without an ultrabell on it...
Old Oct 6, 2005 | 05:41 AM
JRcamaroZ28's Avatar
I have a CSR trans shield on mine...I had to modify the floor a bit to get it to fit but its on and has enought clearance it wont hit anywhere.
JR
Old Oct 6, 2005 | 07:00 AM
Cursed1's Avatar
vette=lack of penis
I have a B&M that fits perfectly without any clearancing. Maybe I got lucky. I also have a JW ultrabell.
Old Oct 6, 2005 | 07:36 AM
silkey's Avatar
i have a 400 with one and it fits,but its close.
Old Oct 6, 2005 | 10:25 AM
kp's Avatar
kp
I use a regular RCI blanket, easy to get on/off even with the trans in the car. I know they suck if your trans leaks but I coudnt get a metal shield to fit at all. The CSR is nice but $$. I can speak from direct experience that a blanket will hold a TH400 direct drum explosion.
As you can see in the pic even with a deep pan it doesn hang down too bad, my car is pretty low and it doesnt rub at all.
Old Oct 6, 2005 | 10:28 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run a CSI supershield, they are like $260 I think.
Old Oct 6, 2005 | 05:34 PM
Maggie's Avatar
Ya, Me too. Except now I believe they are CSR. Part #833 i think. I've done about a 1/2 dozen of these now on th 400 & 350. The first one I did was a pita to get a socket on the bolts but sence then I've started using Ford 4.6 V8 bell bolts, they have a reduced head and make the install much easier.
Old Oct 6, 2005 | 06:28 PM
DERTY's Avatar
The Bull
Like KP said, if you cannot get the shield to fit run a blanket and a ultra bell. The blanket will keep the drum captured.
Old Oct 6, 2005 | 06:43 PM
xssive's Avatar
How hard is the ultrabell to install? My case is sitll one piece. Can I just cut it off here with a cutoff wheel or does it have to be precise?
Old Oct 6, 2005 | 09:01 PM
kp's Avatar
kp
Sawzall, or a hacksaw and a hammer if you feel lucky, will work fine. Just take your time.
Old Oct 6, 2005 | 09:13 PM
mongse's Avatar
I ruin the end of films...
I'm running a Ultra Bell and a CSR sheild w/ no problems. I had to buy my own bolts for the bellhousing though.
